Show messages:  1-16  …  397-416  417-436  437-456  457-476  477-496  497-516  517-536  …  1857-1859
2 Jul 2017   [#457]
Hi All,
Attached is my latest experiment with nodeeditor showing
parametric depth control of flowed geometry over a surface substrate.
BE WARNED: drawing to screen may be up to half a minute.
Have a great weekend
P.S. simple 2nd example added
2 Jul 2017   [#458] In reply to [#457]
Remember my doddling! :)
Message 7777.459 was deleted
9 Jul 2017   [#460]
Hi All,
A simple exercise tessellating surface with tile transformation.
p.s. UPDATED
Message 7777.461 was deleted
16 Jul 2017   [#462]
Any chance Advanced NODE BUNDLE users putting together some YouTUBE demos of their NODES on work methods to give beginners a leg up in the process.
21 Jul 2017   [#463]
Hi to All
An experimental MathSurf tasseling
Stereo Sphere
link :https://www.mediafire.com/?xni7d1ima5h4aio
Have a nice Week -end to all
al
25 Jul 2017   [#464]
Hi Friends
I continue exploring the Minimal Surfaces
Scherk B- Math definition , and low poly modeling
with different assemblies.
link :http://www.mediafire.com/file/x2lur6vde6cj4xq/Scherk-B.rar
Have a nice day to all
al
28 Jul 2017   [#465]
Hi Friends
A Minimal Surf. transition.....
From Catenoid to Helicoid
controlled by a slider
link:
http://www.mediafire.com/file/d38g2c6hvr8m7d6/Catenoid_Trasformation.rar
Have a nice Week-end to all
al
31 Jul 2017   [#466]
Hi Friends
Another test ;
Minimal Surface ,Low Poly Modeling,
Gyroid
link :
http://www.mediafire.com/file/bs8p41ocdhaho19/Gyroid.rar
best
al
31 Jul 2017   [#467] In reply to [#466]
(In Italian)
Ciao AL2000!
Visto quello che riesci a fare con il Project Elephant mi chiedo cosa riusciresti a tirar fuori da Grasshopper per Rhino !!
W la matematica (questa sconosciuta....per me) !
(In English)
Hi AL2000!
Considering what you are able to do with Project Elephant I'm wondering what you can make from Grasshopper for Rhino !!
Maths forever (this stranger....for me) !
Bye.
31 Jul 2017   [#468]
(in Italian)
Ciao Marco
in Grasshopper riesco a tirar fuori molto di più ,
ma il merito è del programma... non mio-
Ci sono una quantità di strumenti disponibili di default nel programma
che fa spavento...
inoltre , ci sono tutta una serie di plug , realizzate gratuitamente da terzi
"amatori" , dedicate ai piu svariati ambiti, prima tra tutte Kangaroo , Wb Mesh,etc. etc
e tante altre
Vale la pena che tu dia un occhiata alle potenzialità del programma
credimi , ne vale la pena-
Però , c'e anche da dire che Elephant , per alcuni aspetti ,
e secondo me innovativo , sopratutto per quanto riguarda il funzionamento
di alcuni Nodi , Math Point , SubD ad esempio con il trattamento delle
Poly Surf come fossero Mesh, etc etc
Tutto merito del Geniale Max-
Ti ringrazio per le belle parole , e ti esorto comunque a scoprire al più presto anche Grasshopper
Buona Giornata
al
(in English)
Hello Marco
In Grasshopper I can get out a lot more,
But the merit is the program ... not mine
There are a number of tools available by default from the program
Scary ...
Moreover, there are a whole number of plugs, made free of charge by third parties
"Amateurs", dedicated to the most varied areas, first of all Kangaroo, Wb Mesh, etc. etc
And many more
It is worthy to give a hint to the potential of the program
Believe me, it's worth it-
However, there is also to be said that Elephant in some respects
And in my opinion innovative in terms of operation
Some Nodes, Math Point, subD for example and the treatment of
Poly surf as if they were meshes, etc. etc
All the credit to the Max's Genius-
I thank you, and exhort you to discover Grasshopper
Have a nice day
al
31 Jul 2017   [#469] In reply to [#468]
Grazie AL.
Cercheró di tornare a dare un'occhiata prima o poi anche a Grasshopper (Ho Rhino da 5 anni e da circa due lo apro solo per scaricare gli update della WIP 6 :)
Buona giornata.
4 Aug 2017   [#470]
Hyperbolic functions, such as sinh and cosh, do not seem to available in nodeeditor v .93.
Are they likely to be available in the future or does the litegraph library not support them?
Mike.
4 Aug 2017   [#471] In reply to [#470]
Hi Mike,
Try:
cosh(u) = ( exp(u) + exp(-u) ) /2
sinh(u) = ( exp(u) - exp(-u) ) / 2
Brian
5 Aug 2017   [#472] In reply to [#471]
Thanks, Brian.
Of course - it worked!
Nice work around.
Mike.
Catenoid surface.nod
6 Aug 2017   [#473]
Hyperbolic Helicoid. HyperbolicHelicoid
Thanks to Brian's formulaic equivalents to sinh and cosh I've got this working.
HyperbolicHelicoid.nod produces a surface which is easily converted into a solid by executing Construct/Offset/Shell using Thickness 0.01mm (for default .nod values) and Direction: Normal
6 Aug 2017   [#474]
Cool: with image + Nod we can decide if yes or no we want load the tool! ;)
Maybe useful for pasta makers ?
6 Aug 2017   [#475]
Hi All - trying to get this node to work but cant realised I am still running node editor 0.91 not 0.93 have searched this thread for update but cant find it - if someone could point me to the latest build would be greatly appreciated.
thanks
alex
6 Aug 2017   [#476] In reply to [#475]
.93:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.596
