Show messages:  1-20  …  1761-1780  1781-1800  1801-1820  1821-1840  1841-1859
6 May 2021   [#1821] In reply to [#1]
Hello all,
Well I am new to Nodeeditor in MOI 3D, I am currently using "nodeeditor 1.1 jms"
I have downloaded the attached files. and I see this:
As you can see "Run" is not active! how can I fix it?
I appreciate any help :)
Thank you Karsten for sharing! :)
6 May 2021   [#1822] In reply to [#1821]
Hi Psygorn (Drillbit),
The picture is very blurred, but it is the very old motor.nod node program, of Karsten. It does not work on my current node editor setup.
(Red in boxes likely indicates missing node(s).)
Instead, try Max's motor2 node:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.203
Note that this link is for an old version, and to make it work, it is necessary to replace the three math nodes with new math nodes, with the same inputs and outputs, and F formulas, to make it work.
The three old math nodes are obsolete "frame" versions...(Note the obsolete "blue" color coding of the wires.) The old color coding is even different from Max's picture, but Nodeeditor has changed
a lot over the years.
There must be a more recent version of motor2, (???), probably with a quartz clock input...
The motor2 node in the link should be updated.
motor2Q.nod has quartz clock, and also needs the motor2.3dm file.
Note that the Motor2.nod node needs the motor2.3dm file of the crankshaft to be loaded into MoI.
I ran (a more recent) motor2 node a few years ago.
The Angle node may be replaced with a Quartz node, with Hz (Hertz) input from Constant node with value 1.
motor2Q.nod
7 May 2021   [#1823] In reply to [#1822]
Tanx bemfarmer,
I used motor2Q.nod and motor2.3dm and it works like a charm! :) tanx
So, it is compatible with current version of nodeeditor?
And one question do we have the ability to search for nodes within the nodeeditor environment? (Like Blender you press F3 and a search combo opens)
Also is it possible to have nodeeditor inside of MOI, like one of its panels? (Objects, Types, Styles)
8 May 2021   [#1824]
Hello guys,
I had created the attached nodes using nodeeditor 1.1 jms.
I wanted to select all created spheres and perform "union" command on them. I faced some difficulties as to I don't know how to select objects within nodeeditor.
My next goal is to find the intersection edges of small spheres with the larger one ( Is it possible to do such thing using nodeeditor?)
any help is appreciated. :)
Spheres.nod
8 May 2021   [#1825] In reply to [#1824]
When you have few number of objects you can make something like this
8 May 2021   [#1826] In reply to [#1825]
Hi PILOU,
I don't get it! I want to select create objects by nodeeditor.
Edit: How one can do it by controlling the movement of objects?
Could you please explain how I should use it to select created objects? So, then I can perform "Union" on them.
Later I would like to know how I can select certain edges using nodeeditor is it possible?
Move.nod
8 May 2021   [#1827] In reply to [#1826]
I am not sure you can "select" an object result : you can take the result for make something with it!
The Union Node works like that (that is here "Selected" by hand) but will be the same if it's an object(s) resulting of something!
https://moiscript.weebly.com/construct.html#bibeunion
8 May 2021   [#1828] In reply to [#1826]
the node you need is the concat.
Barry
8 May 2021   [#1829] In reply to [#1828]
Problem of Nodes system : when you stop for a while you forget all! :)
Even you have made the Library ! ;)
https://moiscript.weebly.com/basic.html#bibeconcat
8 May 2021   [#1830] In reply to [#1828]
Thank you Barry-H :)
By the way do you know if it is possible to do this (Selecting certain edges of unioned mesh) or not?
8 May 2021   [#1831] In reply to [#1829]
I understand PILOU :)
Is there a manual to read and learn the functionality of nodes?
in a glance https://moiscript.weebly.com/construct.html#bibeunion I was not able to find out how "select" works for example.
Should I keep digging into above link?
or is there another source for learning that kind of things.
8 May 2021   [#1832] In reply to [#1831]
You have all nodes here with their explanation so it's not exactly a manual but...
in English...and in French ;)
You have Selected Node
https://moiscript.weebly.com/objects.html#bibeselected
and this shows (2 lines bottom) the action on the Select Node on this page : https://moiscript.weebly.com/node.html
8 May 2021   [#1833] In reply to [#1832]
Ok
So, digging it is! :)
8 May 2021   [#1834] In reply to [#1833]
Bon courage! It's not so evident!
13 May 2021   [#1835] In reply to [#1830]
Hello guys!
I still have don't know how I could select those edges I had highlighted on the attached photo!
Could anyone help me out here?
20 May 2021   [#1836]
Dear all,
I tried to use the OFFSET node to create a bigger version of a closed curve object i.e. a rectangle.
When entering a "Dist" number into the editor of this node, i.e.10, the rectangle gets a 10mm negative offset and is getting smaller. Entering negative numbers is not accepted. Switching the "Both" parameter to "YES" is creating both offset rectangles correctly.
My issue now is that I only want to have the bigger rectangle and not both.
Do I misunderstand the node or do I use it in the wrong way?
Thanks in advance for any ideas or proposals how to get this working.
Joerg
20 May 2021   [#1837] In reply to [#1836]
I will investigate your problem :)
20 May 2021   [#1838]
Maybe like this ?
20 May 2021   [#1839] In reply to [#1838]
Thanks Pilou!
The FLIP parameter is doing the difference!
Really strange, I was pretty sure that I tested yesterday all parameter including different permutations but always failed. But maybe I simply did not test this combination or the restart of the computer solved the issue.
But however now it works, thanks again Pilou!
21 May 2021   [#1840]
I need to do some calcs in a MATH node. I am looking for a function like integer(), but this one seems not to exist.
Do you know where I can find a summary about available functions that can be used in the MATH node? I know the simple + - * / PI sin cos tan ( ) but I assume that there might be more ;o))
Thanks, Joerg
