Show messages:  1-6  …  1567-1586  1587-1606  1607-1626  1627-1646  1647-1666  1667-1686  1687-1706  …  1847-1859
23 Oct 2019   [#1627] In reply to [#1626]
That information is very helpful.
Thank you Karsten.
31 Oct 2019   [#1628]
Maybe this can interest you! :)
https://nodevember.io
8 Nov 2019   [#1629]
Hi All,
Surface Tweening Animations: interpolating z values between 2 point Arrays with randomised z values.
Have a great weekend
9 Nov 2019   [#1630] In reply to [#1629]
Cool!
Does exist a trick for see if the are Macros or not ?
And i see (1-a)*b how do you enter (1-a) ?
9 Nov 2019   [#1631] In reply to [#1630]
>> Does exist a trick for see if the are Macros or not ? <<
Yes, the macros are darker, but there are no macros used in example above.
>> And i see (1-a)*b how do you enter (1-a) ? <<
As well as preset functions, you can type custom functions into Math node's F field.
See image below
>> Cool <<
9 Nov 2019   [#1632] In reply to [#1631]
I must retry because this F case return me nothing! :)
9 Nov 2019   [#1633] In reply to [#1632]
After typing in an equation in the F field, press enter, otherwise the entry goes away.
(Slightly annoying). When typing a more complex equation, save a partly correct entry, then re-edit,
otherwise partial work could be lost.
10 Nov 2019   [#1634] In reply to [#1633]
Good to know!
15 Nov 2019   [#1635]
Recursive subdivisions in NE
Message 7777.1636 was deleted
8 Dec 2019   [#1637] In reply to [#1636]
WOW! Congrats!
Message 7777.1638 was deleted
29 Dec 2019   [#1639]
Now with Wayne's latest update to ImgSampler node ( https://moi3d.com/forum/index.php?webtag=MOI&msg=9581.57 ) it's possible to have 3 images of RGB channels (separated in photoshop) output to interleaving dot screens as shown.
1 Jan 2020   [#1640] In reply to [#1639]
Klaus Nomi ? (but i have not my glasses...
Happy new year!
Message 7777.1641 was deleted
9 Jan 2020   [#1642]
Alex
In answer to your query :
http://moi3d.com/forum/index.php?webtag=MOI&msg=9581.106
please find .nod file for ImgSample to Hex Pattern.
A series of images showing node circuitry can be found here:
https://www.instagram.com/p/B7HZl5NJ_hp/
Let me know if this is not what you meant
gandhi.nod
10 Jan 2020   [#1643] In reply to [#1642]
Intricated! :)
10 Jan 2020   [#1644]
HI James,
WOW! Thats exactly what I meant looks great thanks very much for looking into it for me a great addition to the expanding node list. Will have a play with it and post any outcomes.
Very inspirational work keep it going.
Best regards
Alex.
12 Jan 2020   [#1645]
A variation on Max's dot-screen portrait of Che: http://moi3d.com/forum/index.php?webtag=MOI&msg=7547.55
incorporating the use of 2 of Wayne's node contributions:
ImgSampler & Spiral nodes.
12 Jan 2020   [#1646] In reply to [#1645]
Pop years 60 revival!
