Show messages:  1-9  …  970-989  990-1009  1010-1029  1030-1049  1050-1069  1070-1089  1090-1109  …  1850-1859
31 May 2018   [#1030] In reply to [#1029]
Hi James
That don't work for me
Nothing happen when i modify the bottle or i have message error
I have change index , quit , reopen but no way
Thanks again for your time
1 Jun 2018   [#1031] In reply to [#1030]
Finema, is the modified bottle named " bottle"?
1 Jun 2018   [#1032] In reply to [#1031]
yes
i join the 3dm file with the new bottle
thanks
1 Jun 2018   [#1033] In reply to [#1032]
It works with "surface index" switch set to 0
Did you read instruction on my earlier post?
1 Jun 2018   [#1034] In reply to [#1033]
yes i've read it
but i've tested with 2 and 3
it works with 0
thanks a lot James , it's really usefull for me to design pattern on model !!!
1 Jun 2018   [#1035]
Hi Finema
You can Replace the mFlow node that appears in red
with original Flow node, which you find under the Trasform Tool ( Max's Tool)
just make the connections in and out
with the other nodes, as well as for actual mFlow node ...
I hope I was clear, it's easy enough
Have a nice day
alberto
1 Jun 2018   [#1036] In reply to [#1035]
Thanks Alberto
it's OK with Flow node now
This node is usefull but i need to draw the module and bottle myself on the scene.
Thanks a lot
1 Jun 2018   [#1037]
Hi Finema
As in the example posted by James you can create the references ,
in this case the bottle and the form you want to apply, then
you have to create two nodes (get by name) and then connect them
to the rest of the nodes of my file, (eliminating the bottle and the form
built with only the nodes ...)
All clear .... I hope so
best
alberto
1 Jun 2018   [#1038] In reply to [#1037]
Alberto,
yes it's clear but i don't know what i must exactly put the getbyname node
and also, what i must delete
I'm discovering node editor, sorry
1 Jun 2018   [#1039]
Hi James
I carefully reviewed your last file, and I allowed myself to add
some steps to get a scaling on the faces for the Flow ...
I think it can be useful ---
file to this link:
http://www.mediafire.com/file/rx36d7931u1iuvu/bottleWrap4.nod/file
In any case, I have to ask you some questions;
1- why the progression for isocurve input starts from 0.0001 and not from 0 ....
2- the value 0.0001 is accepted, as ever, in some situations in which I tried to insert it, for other nodes, I could not, the value
it is not accepted .... it depends perhaps on some settings that I do not know .......
3- I saw that the added (info box) to the surface object of the flow,
then splitting the input of the value z, which means .....
grateful for your explanations
Have a nice day and good work
alberto
1 Jun 2018   [#1040]
Hi Finema
a this link:
http://www.mediafire.com/file/kqm1csr5w6b2g0o/31-05-Bottle_SimPanelingTool.zip/file
new file with object referenced
and new Flow node
only run... Good Luck
alberto
1 Jun 2018   [#1041] In reply to [#1040]
Thanks Alberto
it's Ok now
I would like to use a solid instead an half surface
1 Jun 2018   [#1042] In reply to [#1041]
Thanks a lot James and Alberto
I know it's not as Paneling Tool Rhino but this node is usefull for my work
1 Jun 2018   [#1043] In reply to [#1039]
Hi Alberto,
In answer to your questions 1& 2. It seems it is no longer necessary to commence progression with 0.001.
This a hang over from an earlier version of isoCrvs, as you can see in image below it now does it automatically,
so that's good to know.
Question 3..the info box node ascertains whether the idxSelected surface has a z dimension.
An output of 0.00 for bottle base translates as boolean false and hence breaking the circuit,
while and other dimension translates as true.
It works better with inclusion of blue nodes in attached
I have only just awoken, so I have not had a look at your file. I'll do that now,
I've had a look: Yes your added nodes could be useful, thanks for that
Have a great weekend
1 Jun 2018   [#1044] In reply to [#1043]
Hi
Why the pattern isn't similar to the model (bottle)
See my screenshots
The pattern is not perfectly following the shape of the bottle.
Message 7777.1045 was deleted
2 Jun 2018   [#1046] In reply to [#1045]
OK
Thanks James :)
2 Jun 2018   [#1047] In reply to [#1046]
Finema
The reason "pattern is not perfectly following the shape" is due to the fact that the bottle surface has been rebuilt. It fidelity of the bottle is significant, then there are work arounds. I'll get back to you
See if the attached works for you. Instead of rebuilding the bottle; it has been sliced/diced.
2 Jun 2018   [#1048] In reply to [#1047]
It's perfect now !
the script running is slower but it's great !
thanks a lot
Message 7777.1049 was deleted
