Show messages:  1  …  962-981  982-1001  1002-1021  1022-1041  1042-1061  1062-1081  1082-1101  …  1842-1859
31 May 2018   [#1022] In reply to [#1021]
waoouu ! Great !
it's a good start !
i have tested with a knurl pattern but the result is not uniform, the modules are streched and overlap
thanks again
31 May 2018   [#1023]
Hi Finema and friends
at this link:
http://www.mediafire.com/file/kqm1csr5w6b2g0o/31-05-Bottle_SimPanelingTool.zip/file
you will find the file, to adapt the object to the surface,
as you will see the approach is different from the amount that you have
posted James ... I think this also has its validity
Certainly it is not the paneling that can be achieved with
Paneling Tools- or Rhino's Morph Box (Grasshopper)
but it's always a good start for Moi-
You just have to open the file and then run it,
you will see different parameters, rows, columns, etc etc ...
change them to see how they work-
Have a nice day to all
alberto
31 May 2018   [#1024] In reply to [#1022]
Hi Finema,
This is an alternative simpler approach:
Click RUN
If nothing happens, click "Surface Index" switch
The target surface should be index either 0 or 1.
In the event nothing still happens, try changing "const" node values to 2 & 3
& if you desire the bottle to be shown, click "switch" to reveal
for .3dm & .nod file see:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1043
31 May 2018   [#1025] In reply to [#1023]
Hi Alberto,
How i can use it ?
Must i name object ?
Thanks a lot.
31 May 2018   [#1026] In reply to [#1024]
Thanks a lot James
It's very good
But i have an error when i want to change the bottle.
UNSUPPORTED POLYGON TYPE 15
31 May 2018   [#1027]
Hi Finema
you simply have to open the file
and run ... all the data is in the file, there are not any
referenced objects
best
al
31 May 2018   [#1028] In reply to [#1027]
Al,
You don't join a 3dm file
I think some .js are missing in my node editor
mflowObj is red
thanks
31 May 2018   [#1029] In reply to [#1026]
Hi Finema,
>> error when i want to change the bottle. UNSUPPORTED POLYGON TYPE 15 << .
The issue is the indexing of the surfaces of the bottle.
I have updated my previous post with new nod file
& instructions
31 May 2018   [#1030] In reply to [#1029]
Hi James
That don't work for me
Nothing happen when i modify the bottle or i have message error
I have change index , quit , reopen but no way
Thanks again for your time
1 Jun 2018   [#1031] In reply to [#1030]
Finema, is the modified bottle named " bottle"?
1 Jun 2018   [#1032] In reply to [#1031]
yes
i join the 3dm file with the new bottle
thanks
1 Jun 2018   [#1033] In reply to [#1032]
It works with "surface index" switch set to 0
Did you read instruction on my earlier post?
1 Jun 2018   [#1034] In reply to [#1033]
yes i've read it
but i've tested with 2 and 3
it works with 0
thanks a lot James , it's really usefull for me to design pattern on model !!!
1 Jun 2018   [#1035]
Hi Finema
You can Replace the mFlow node that appears in red
with original Flow node, which you find under the Trasform Tool ( Max's Tool)
just make the connections in and out
with the other nodes, as well as for actual mFlow node ...
I hope I was clear, it's easy enough
Have a nice day
alberto
1 Jun 2018   [#1036] In reply to [#1035]
Thanks Alberto
it's OK with Flow node now
This node is usefull but i need to draw the module and bottle myself on the scene.
Thanks a lot
1 Jun 2018   [#1037]
Hi Finema
As in the example posted by James you can create the references ,
in this case the bottle and the form you want to apply, then
you have to create two nodes (get by name) and then connect them
to the rest of the nodes of my file, (eliminating the bottle and the form
built with only the nodes ...)
All clear .... I hope so
best
alberto
1 Jun 2018   [#1038] In reply to [#1037]
Alberto,
yes it's clear but i don't know what i must exactly put the getbyname node
and also, what i must delete
I'm discovering node editor, sorry
1 Jun 2018   [#1039]
Hi James
I carefully reviewed your last file, and I allowed myself to add
some steps to get a scaling on the faces for the Flow ...
I think it can be useful ---
file to this link:
http://www.mediafire.com/file/rx36d7931u1iuvu/bottleWrap4.nod/file
In any case, I have to ask you some questions;
1- why the progression for isocurve input starts from 0.0001 and not from 0 ....
2- the value 0.0001 is accepted, as ever, in some situations in which I tried to insert it, for other nodes, I could not, the value
it is not accepted .... it depends perhaps on some settings that I do not know .......
3- I saw that the added (info box) to the surface object of the flow,
then splitting the input of the value z, which means .....
grateful for your explanations
Have a nice day and good work
alberto
1 Jun 2018   [#1040]
Hi Finema
a this link:
new file with object referenced
and new Flow node
only run... Good Luck
alberto
1 Jun 2018   [#1041] In reply to [#1040]
Thanks Alberto
it's Ok now
I would like to use a solid instead an half surface
