Full Version: Parametric design in MoI?
Show messages:  1-2  …  823-842  843-862  863-882  883-902  903-912
10 Jun 2020   [#883] In reply to [#880]
Hi Wayne,
> This is an error on the current version of the Node Editor that happens when pressing "Load" then "Cancel".
I investigated this some more and it turns out that it is not a bug in the Node Editor, it is a bug in MoI's file dialog handling. The bug crept in with a change a couple of betas ago to remember the last used file dialog directory so the dialog will start out in that directory. It ends up returning that directory name when you cancel when it should be returning an empty string.
The node editor code is already checking for an empty string like it should.
I've got it fixed up for the next v4 beta, thanks for reporting it.
10 Jun 2020   [#884] In reply to [#883]
Thank you Michael. I thought it was a Node Editor error and was attempting to fix it on my own with no luck. Was also looking into having the Node Editor prompt a save before exiting.
-w
24 Jul 2020   [#885] In reply to [#642]
When I select the “Export” command there is no dialog or options to export as shown in your post.
24 Jul 2020   [#886] In reply to [#885]
It's maybe for a MAC user ?
I have not also this...but my Macro is well exported... ;)
24 Jul 2020   [#887] In reply to [#754]
I unzipped the Extensions.zip file into the [C:\...\AppData\Roaming\Moi\nodeeditor\nodes\extensions\]
It created another Extensions folder.
But how do I access these?
6 Oct 2020   [#888]
Could someone suggest where I might start as a beginner with the Node Editor.
Website?
Forum Page?
Tim
6 Oct 2020   [#889] In reply to [#888]
Hi Tim
http://moi3d.com/wiki/Nodeeditor
Some of the information is not up to date...So recent forum posts may be helpful for install.
Max's site has the latest version.
An it runs just fine on MoI4Beta.
6 Oct 2020   [#890] In reply to [#889]
This looks like what I needed, Thanks so much.
Tim
6 Oct 2020   [#891]
https://moiscript.weebly.com/biblio-elephant.html ;)
6 May 2021   [#892] In reply to [#891]
Hi PILOU,
What is the difference between your Elephant & Max's Node editor?
Are they the same?
Your website provides the latest version of it?
Or we should go to Max's webpage?
I get kind of confused what is VF what is VO? and which version works best on MOI V 4.0?
I am using Windows.
6 May 2021   [#893] In reply to [#892]
Yes Elephant is the name of the Node Editor for Moi by Max Smirnov
It's it that i have on my site!
VO = Original English Version
VF = French Version of the Native Nodes of Elephant (but has also no native nodes but these no native are not translated)
All versions works fine with Moi.4.0
<< Or we should go to Max's webpage?
No Lastest version of Elephant is the Version modifyed by creators of nodes so many more nodes than original Elephant
and managed by James http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.10
there you can download a zip NodeEditor !
But maybe Max will made soon a new version after the release of the who knows! :)
6 May 2021   [#894] In reply to [#893]
I ended up with an error!
I have downloaded "nodeeditor.zip" from: http://moi3d.com/forum/index.php?webtag=MOI&msg=9949.12 (Post number = 9949.12)
then I extracted the zip file into ...AppData\Roaming\Moi
and then I made a shortcut for it "Alt+N" and added : ​moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
but I ended up with an error!
What should I do?
6 May 2021   [#895] In reply to [#894]
Hi Psygorn, that error means you've got some unusual text characters inserted into the shortcut key text. Maybe if you're preparing the text in a word processor that has styles and such applied to it that is carrying along some extra stuff. Try using a plain text editor or set the document type to be plain text.
6 May 2021   [#896] In reply to [#894]
Did you get that text by selecting and copying from a web page? If so which page, maybe I can fix the page to not have fancy unicode control characters in what is supposed to be plain text for code.
Try this:
script:moi.ui.createDialog("moi://appdata/nodeeditor/index.html","resizeable,defaultWidth:680,defaultHeight:420",moi.ui.mainWindow);
6 May 2021   [#897] In reply to [#895]
Is that it:
I used this piece of code for a short key:
script: if ( moi.majorVersionNumber == 3 ) { moi.ui.createDialog( 'nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow ); } else if ( moi.majorVersionNumber == 4 ) { moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow ); }
Does the above code works by omitting the term "script:" ?
I think it does work with or without it!
6 May 2021   [#898] In reply to [#896]
I took it from Pilou's page here: https://moiscript.weebly.com/install-elephant.html
6 May 2021   [#899]
Is there a place in which people share their nodes? Or tutorials?
6 May 2021   [#900] In reply to [#897]
Hi Psygorn,
> Is that it:
Yup, that is what it looks like when it's running. You can right click in there to start adding nodes.
6 May 2021   [#901] In reply to [#899]
<< Is there a place in which people share their nodes? Or tutorials?
You can find tones here! ;)
https://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1
6 May 2021   [#902] In reply to [#901]
Tanx PILOU :)
