686-705
706-725
726-745
746-765
766-785
786-805
806-825
906-912
Ok I have made my own for be sure to understand what i made! :)
With SumpoPaint of course! :)
https://www.sumopaint.com/home/#app
Just curious logo is not centered on the Menu's Lines?...
Maybe the original is not exactly at the center...
Edit : even the original is centered result is bottom offseted! ?
Hello Max,
I made a first experiment with an icon. Is it true that we will lost the node state (green, orange,red).?
Have a nice evening
Karsten
I have been playing with adding Icons in the node editor to see if they can be recognised at the 64 x 64 size.
On my surface Pro even when zoomed in I don't think over detailed icons will be recognised.
Any idea's on best colour's ?
Barry
For Max and all nodes lovers! :D
Official nodes + Extensions!
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/lang_21_12_17_vf.zip
Hallo together,
where can I find the current instructions how to install the nodeeditor on V4.
Have a look here:
http://moi3d.com/wiki/Nodeeditor
Ralf, thank you, it functioned well. Had to replace just the name of the folder.
Now I need a nodeeditor beginner tutorial.
Rudl
Hi Rudi,
unfortunally there is no tutorial about the nodeeditor... its still a project in development.
But a good point to start is this forum ore the thread
http://moi3d.com/forum/messages.php?webtag=MOI&msg=7777.1
You will find a lot of examples for whats possible to do with the nodeeditor.
An other thing are the extensions - a lot of people write special plugins for nodeeditor.
I will attach my extensions folder - i think its mostly complete. It goes into the nodeeditor folder
Have fun with nodeling!
extensions.zip
Hi Ralf,
thank´s for the extensions. Integrated it in the extension folder. Now I must find out, what to do with them.
Because i think that this is the first of my Node creations which i think is USEFULL i post it in this thread...
THE DOVETAIL TRAY MAKER
HOW TO USE IT
Open the attached dovetailcase5.nod in MoI > hit run... and you see this:
Change the dovetails to your needs. And hit APPLY
NOW SWITCH BOTH SWITCHES ("Left/Right" and "Boards") and you can design a different Dovetail for the opposite side...
HIT APPLY AND CLOSE THE NODEEDITOR...
You will see the tray with the dove maker tools
Now select the upper and lower board and DO A BOOLEAN DIFFERENCE with the correspondending (the outer ones) tools to cut the dovetails:
Do the same with the other two boards:
You have the dovetail tray!
Do some small chamfer...
You can also make a small gab between the two parts - VERY USEFULL IF YOU 3D PRINT IT - and it brings a snuggly fit...
As a joiner i would be proud of it!
And there are NO SPECIAL EXTENSIONS used..
HAVE FUN !
dovetailcase5.nod
@r2d3
Will be fine if any 2 intersected volumes can be used! ;)
French version is in Progress!
"Open the attached dovetailcase5.nod in MoI > hit run... and you see this:"
Hi
When i load dovetailcase5.nod i can't hit run (show screenshot)
and a part of nodes are red..
Your node extensions are not up to date...
Look here for a actual one...
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.753
Have fun
Thanks Ralf ! it's great !
Let the Dove-tools jump over a FLOW-command and you can do also round edges...
Forgotten this tricky trick! ;)
With this extended Tool you get also the Polylines to make it easier for FLOW operations...
The cyan line is for the dove cutting the blue for the tinnes and the magenta (selected on pict) is the baseline.
dovetailcase6.nod
French Version of DoveTails by r2d3 :
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/lang.js
Wow ! Merci Pilou !
Sinusoïdal!! :)
PS A little video will be fine for all the process!
Say for an Ellipse...rectangular :)
686-705
706-725
726-745
746-765
766-785
786-805
806-825
906-912
