Full Version: Parametric design in MoI?
Show messages:  1-19  20-39  40-59  60-79  80-99  100-119  …  900-912
30 Nov 2015   [#40]
I have this at start but after all works fine! (Maybe an extra translation of something...)
Or maybe the default node that I have erased in previous session ?
And quasi all nodes are now in French! Not so evident! :)
30 Nov 2015   [#41]
Hi Max
Great Job... Wonderful
Your Plug make a quality jump to Moi...
I have a question ;
Can I install the plug NodeEditer , without , before to install
Custom UI in my computer
thanx
al
30 Nov 2015   [#42]
>> Generally all words between 2 "" ?
No. You can safely change only "In" "Out" Loft.title Loft.desc
P.S. Don't waste your time. Wait for the beta version.
speedy
>> Can I install the plug NodeEditer , without , before to install Custom UI in my computer
Yes. You need to extract archive to /ui/ directory and then bind "moi.ui.createDialog...." command to any button you want (Options/Shortcut keys).
30 Nov 2015   [#43] In reply to [#41]
You dont need custom ui. Put the zip files in the moi ui folder and then make a shortcut with the line of code in the post.
30 Nov 2015   [#44] In reply to [#42]
@ Max
Cool to know!
As all is quasi done, I am waiting now the beta! :)
30 Nov 2015   [#45]
I began an extremely rough initial documentation, which I hesitantly post here. :-)
Documentation for NodeEdit program002.pdf
30 Nov 2015   [#46] In reply to [#42]
Hey Max,
Just loaded it and am getting a blank white dialogue window... Have you seen this yet?
Using windows 7. Nothing particularly different from a default install of it.
[EDIT] Please disregard.... I installed the files incorrectly. Got it sorted out....[EDIT]
1 Dec 2015   [#47] In reply to [#45]
Did a revision of one paragraph of documentation, post 45.
1 Dec 2015   [#48]
Frame node rewritten
Added Rotate object node
extract this archive to /ui/nodeeditor/nodes/
bemfarmer
Thank you!! Great!
1 Dec 2015   [#49]
Keep the impetuous work! Excellent!
Very cool video explanation!
2 Dec 2015   [#50] In reply to [#49]
today I'll add a multilanguage support to this project. Could you make french translation using this form:
"Out" : "Vers",
"Radius" : "Rayon",
"Knob" : "Potar",
"X axis" : "..."
2 Dec 2015   [#51]
Had a very brief peek at the code to see about trying to code catenary, or something.
(This may be within my capability, after the roof leaks are patched:-)
Searched on the litegraph link and saw a demo. (Non Moi)
http://tamats.com/webglstudio/litegraph/demo/
Several dozens or hundreds of Objects, etc, left to program...
2 Dec 2015   [#52] In reply to [#50]
@Max
No problem!
Perfect : I will make that in no time this evening! :)
Like this ;)
"Out" : "Vers",
"Radius" : "Rayon",
"Knob" : "Potar",
"In" : "De",
"X axis" : "Axe X",
"Circle" : "Cercle",
"Sphere" : "Sphère",
etc...
In general it can arrive some problems with accents! (UTF / ANSI)
For the moment seems I must convert to ANSI when I edit the file and resave!
You will post a text(s) file(s) ressource with list with some items with empty second part of line like above
or I must collect myself some words in some existing little files ?
(i am not sure in all cases if it's a real word to translate or a variable or other! ;)
2 Dec 2015   [#53] In reply to [#52]
Frenchy Pilou
>>"In" : "De",
>>"X axis" : "Axe X",
Exactly :)
It's ok. Just convert the file to UFT and send it to me.
>>I must collect some words in some existing little files ?
Yes, but you don't need to dig into the files. Just translate everything you see. Order doesn't matter.
2 Dec 2015   [#54] In reply to [#34]
Max,
Does this only work on a Mac? I just get a blank screen pop-up on my PC (of course it could be user error :-)~
Michael T.
2 Dec 2015   [#55] In reply to [#54]
it should work, check the installation paths.
2 Dec 2015   [#56] In reply to [#55]
I think my problem is not being able to download the .htm file. It just opens in another tab.
Michael T.
2 Dec 2015   [#57] In reply to [#53]
<<< Yes, but you don't need to dig into the files. Just translate everything you see. Order doesn't matter.
Ok You will have your file in some few moments! ;)
PS Have you a synonym of "Frame" ? Because in your context i am perplex! :)
2 Dec 2015   [#58]
update
added multilanguage support :)
Pilou, your turn ;)
P.S. Coordinate frame
http://images.tutorvista.com/cms/images/113/cartesian-plane-3d.png
2 Dec 2015   [#59] In reply to [#56]
Hi Michael Tuttle,
The entire extracted folder goes into the ui folder. Not the contents. So your moi ui folder will have a new nodeeditor folder with the contents in there.
The htm file will just put an icon on the bottom toolbar area to launch it. Try right clicking the file and download it with a "save target as" or whatever your browser presents in the right click.
