Full Version: Parametric design in MoI?
Show messages:  1-4  5-24  25-44  45-64  65-84  85-104  …  905-912
24 Nov 2015   [#25] In reply to [#22]
Unbelievable, this is realy great. Bringing MoI closer to tools like Houdini etc.
Great work Max
24 Nov 2015   [#26]
hello ,
it is possible integrate appleseed or similar?
http://appleseedhq.net/features.html
http://appleseedhq.net/gallery.html#http%3A%2F%2Fappleseedhq.net%2Fimg%2Fscreenshots%2Fgafferseed.jpg
25 Nov 2015   [#27]
Preview 3
James,
>>I think there is a real business opportunity here.
Maybe.. Anyway this script will be free for every MoI user.
Frenchy Pilou
>>Any functions valuable ?
Sorry, I don't understand you question.
guyver
Everything is possible. But I have no plans about it. ;)
Vojtisek, Karsten, Frenchy Pilou, James thank you! :)
25 Nov 2015   [#28] In reply to [#27]
Very neat!
@ Max
Just if all functions of the Moi UI will be present on the nodes system! ;)
Another thing : your nodes will be easily accessible for translation ?
Like this for example
25 Nov 2015   [#29] In reply to [#27]
It's looking really cool Max, I think a lot of people will be interested in it!
26 Nov 2015   [#30]
It's looking cool indeed, time to parametrize some stairs!
Thanks Max,
Max.
29 Nov 2015   [#31]
Frenchy Pilou
Not every function can be implemented.
At the moment this program doesn't support translations at all. The engine uses names of variables as labels. So, you can't just rename labels.
I'll make multilanguage support later. But now it will be English only.
29 Nov 2015   [#32]
Good news :) Today evening will be first public release of this node-editor.
Btw, could somebody help me with documentation? As you can see, my english is far from perfect, so I'll waste a lot of time if I do it myself.
I definetely need help :)
29 Nov 2015   [#33]
Suspense! ;)
29 Nov 2015   [#34]
v0.2 alpha (tech demo)
Extract .zip archive to /ui/ directory:
\ui\nodeeditor\index.html
\ui\nodeeditor\core\imgs
\ui\nodeeditor\core\litegraph-editor.js
\ui\nodeeditor\core\litegraph.js
\ui\nodeeditor\core\imgs\*
\ui\nodeeditor\css\litegraph-editor.css
\ui\nodeeditor\css\litegraph.css
\ui\nodeeditor\css\style.css
\ui\nodeeditor\nodes\basic.js
\ui\nodeeditor\nodes\factories.js
\ui\nodeeditor\nodes\interface.js
\ui\nodeeditor\nodes\objects.js
use this command to run the script:
moi.ui.createDialog( 'nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow )
You can run this script using CustomUI addon. Put attached "99 NodeEdit.htm" file to /ui/customui/ directory and restart MoI.
29 Nov 2015   [#35] In reply to [#34]
It works, I like the interface also.
Of course the more functions available, the better it gets.
Thank you
29 Nov 2015   [#36]
Custom UI : http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1
29 Nov 2015   [#37]
Works fine! Very neat! And very smart when you have 2 screens! Bravo!
French Version of the Install! ;)
The tricky thing is (re) install the Custom UI if not existing! ;)
No Erase All or New?
No Undo ? (When create some nodes)
A very minor default : little flickering when we resize the window ;)
Seems translation possible with some attention to the code! :)
Access to the nodes
Here the Nodes accessible : Maybe I have forgotten something ?
Properties of the nodes
29 Nov 2015   [#38] In reply to [#32]
Hi Max,
I'll try to help with documentation.
30 Nov 2015   [#39]
@Max
In this portion I must translate only red lines : more, less? I am not sure for the "objectlist"...
Generally all words between 2 "" ?
30 Nov 2015   [#40]
I have this at start but after all works fine! (Maybe an extra translation of something...)
Or maybe the default node that I have erased in previous session ?
And quasi all nodes are now in French! Not so evident! :)
30 Nov 2015   [#41]
Hi Max
Great Job... Wonderful
Your Plug make a quality jump to Moi...
I have a question ;
Can I install the plug NodeEditer , without , before to install
Custom UI in my computer
thanx
al
30 Nov 2015   [#42]
No. You can safely change only "In" "Out" Loft.title Loft.desc
P.S. Don't waste your time. Wait for the beta version.
speedy
>> Can I install the plug NodeEditer , without , before to install Custom UI in my computer
Yes. You need to extract archive to /ui/ directory and then bind "moi.ui.createDialog...." command to any button you want (Options/Shortcut keys).
30 Nov 2015   [#43] In reply to [#41]
You dont need custom ui. Put the zip files in the moi ui folder and then make a shortcut with the line of code in the post.
30 Nov 2015   [#44] In reply to [#42]
@ Max
Cool to know!
As all is quasi done, I am waiting now the beta! :)
