Full Version: Parametric design in MoI?
Show messages:  1-2  …  83-102  103-122  123-142  143-162  163-182  183-202  203-222  …  903-912
28 Dec 2015   [#143] In reply to [#142]
Hi Barry,
sorry there is a named selection in it. Delete it. It is the input of the first gen array. Replace it with what you want, or use this one.
Karsten
array21.nod
28 Dec 2015   [#144]
A funny one will be to emulate the LineWeb! ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=3666.10
29 Dec 2015   [#145] In reply to [#144]
Hello Pilou,
very cool and I like your sense for colors!
By the way - Here is something I am working on. A curvearray with induvidual spacing, scaling and rotation. It is full of bugs at the moment, so I want to share only a gif at the moment. The naming has not a reference to the real function, because it was written for another context:-)
Have a nice day
Karsten
29 Dec 2015   [#146] In reply to [#145]
Bon courage! :)
In another sort of idea: Can we imagine a Knob/ Slider of Knobs/Sliders?
For use several ones in the same time!
29 Dec 2015   [#147]
This is a quite interesting bit of work done by Max. It provides some very powerful capabilities, but at somewhat of a steep learning curve-- not Max's fault.
It reminds me of the function editor of Vue. The very first time I used it, I was pretty much overwhelmed. Over years I became fairly adept and could create dense cloud structures, hypertexture volumes and interesting fractal landscapes. In talking with the Vue programmers, they too recognized the challenge the function editor posed to most users and decided to provide an 'abstraction layer' for the interface.
What this meant is folks like my friend Dax Pandhi could now take his elaborate functions and distill them into a few custom named sliders, hide the rest and allow the rest of us to be able to use them without having to understand vectors, max/min, what different fractals did, etc.. I think it was a smart move by Vue and also helped the community (and Dax!) significantly.
I would think something along an 'abstracted' interface might be worth exploring. As always, I'd encourage Max to sell this significant technology in order to find a way to help support it.
30 Dec 2015   [#148]
Hi Karsten,
attached is my attempt for a grid array with adjustable centres,columns and rows in the 'X' & 'Y'
and the ability to rotate the object. I'm not sure if it's the proper way to do it but it works.
Will you have a look and let me know if it's Ok.
It would be good if the Generative Array info could be accessed as I needed to reset one of the values
of the inputs after removing a connection.
Many Thanks.
Barry.
arrayx2.nod
30 Dec 2015   [#149]
Tracks & nodes draw a gun! ;)
30 Dec 2015   [#150] In reply to [#148]
Hi Barry,
I'm not an expert, so I can't decide if this is a proper way, but I think everything works fine. I'm playing with the @'Y'@ like some others, too. Remarked by chipp, the system is not easy to use at the moment, but playing with it, will help to find better solutions.(like your comments:-))
Max announced some changes in the core system that will help reduce wiring, but maybe some nodes have to be changed, alot will be obsolete. I'm not a programmer and time is limited, so I will have a look to a reset function or some better defaults, with the next version of max core system.
Keep on playing:-)
Have a nice day
Karsten
30 Dec 2015   [#151] In reply to [#150]
Hi ,
being a beginner I'm posting this file hoping for some feed back on where I could
improve it or make it easier.
The attached node file as two arrays combined to allow nesting of objects.
In the picture the red and silver objects are the same. This was an exercise to maximise
a mould layout for a given shape with the ability to rotate and adjust and offset centres.
Barry
Nesting.nod
Message 7713.152 was deleted
Message 7713.153 was deleted
31 Dec 2015   [#154] In reply to [#153]
Hello Barry, Hello James,
It should be a bug if it isn't work. I will have a look tomorrow.
Very interesting to see the different application areas and different point of view to the same thing.
Sorry, if there are bugs in the nodes.
Happy new year to all
Karsten
1 Jan 2016   [#155] In reply to [#154]
Hi James & Karsten,
I'm not sure if this may help but I replicated James problem and found you could
produce the sine wave in the X & Y or Y & X also X & Z but not Y & Z.
Happy new year
Barry.
1 Jan 2016   [#156] In reply to [#155]
Hallo Barry,
Thank you for your investigations. The problem is that I check the input of x(n) and generate not an default array for that. So if you put an array with the same number of values, with start value 0 and step 0, it should work (all ports connected to avoid side effects). I am waiting till next alpha of the @'y'@ to find a better solution, because Max has announced big changes in value handling - maybe he will integrate some better solutions by himselve? I'm very curious:-)
Kind regards
Karsten
2 Jan 2016   [#157]
@ = Ear
' = Eye
Tusks missing
y = Trunk and Jaw?
http://pc.net/emoticons/smiley/elephant
12 Jan 2016   [#158]
Hi everybody! :)
I'm back from vacations. New alpha/beta vesions will be soon :)
12 Jan 2016   [#159] In reply to [#158]
Happy new year MAX!
Made with the incredible free Verve: we can now embed an image inside bristles Brush!
http://www.taron.de/forum/viewforum.php?f=4
12 Jan 2016   [#160] In reply to [#158]
Hello Max,
Happy new year! I am very excited about the changes you have made:-) and I hope, I will understand them!
Kind regards
Karsten
15 Jan 2016   [#161] In reply to [#160]
Hello,
I want to share my last investigations of subD for the elephant. I have simple wrapped Max SubD-Script in a node. Sorry about the videoformat. It's my first screenrecording and I have some problems with the upload.
Kind regards
Karsten
15 Jan 2016   [#162] In reply to [#161]
You will not erase this one ? ;)
