2-21
22-41
42-48
Yes and can be also cool for rings! ;)
French version :
http://moiscript.weebly.com/scripts-de-max-smirnov.html
The trick for fill them in case of Fat Lines curves 3D!
Separate then Loft! ;)
Hey, that's great Max, many thanks, much appreciated!
Hi Max,
First : thank you for your many contributions very very useful !
I have a question about this script: Is it possible to add an option to automatically fill in the result of this "thick line" with a new custom style (black by default, like the boom in "dimensions" script) ?
To make " classic " technical drawing (no color) , we have several tools :
- "Hatch-it" script
- "Dimensions" script
- "Fatlines" script
For completeness, it should miss perhaps a tool for making drawn dashed . Maybe I can detail this point if it interests people other than me ! (
https://en.wikipedia.org/wiki/Engineering_drawing#/media/File:Line_types.png)
Bear
This is great fun thanks guys
Can history be enabled ? if possible so if you change the base lines the output updates
cheers
shayne
Hi, how did you re import the subdivision model? I have yet to find a way to figure out how to import .obj's as simple as you make it sound.
T
As you export as OBJ from Moi
you can re-import the same File with ImportOBJ by Max Smirnov !
http://moi.maxsm.net/media/files/ (scroll)
2-21
22-41
42-48
