14-33
34-53
54-73
74-79
When I download the .zip file for the Bridge script I only get 1 file: _sBridge.js. There is no .htm file included. Is there something missing or is the .htm not required for the bridge command.
No need for the function Bridge : Generaly htm is used for UI, menu, parameter etc...
So make just a short cut or press tab then write _bridge (upper caser letter(s) or not but don't forget the "_") !!!
Hi Wlawton,
That's normal that there's no .htm file for that particular command.
The .htm files contain user interface elements for a command like buttons and checkboxes and stuff like that. If the way a command works is that it just immediately performs an action and doesn't have any UI for buttons and options or things like that, then it may not have an .htm file in it.
Hi
I found adding the scripts a bit confusing at first and struggled along installing them piecemeal before discovering there is a link that allows you to install them all complete with a new set of icons in Moi's UI. Oddly nobody ever seems to point this out despite the tools being present in some tutorial videos. I'm off to work now but you should be able to find them on Max's page
http://moi.maxsm.net/startpos/8. And looking at this thread I'm missing a few:)http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1
I gave up on making a car when Carrara kept ripping up the smoothing. I found half an old model today so put some wheels on it and rendered it in Simlab. I like the smooth surfaces but I don't think I will finish the model as I feel like doing something new.
Moi is really amazing!
Very elegant!
14-33
34-53
54-73
74-79
