2-21
22-37
Hi Scott, here's a quick start:
Copy the file hatchit.js in the commands folder
Restart Moi
Draw a closed shape
Select it
TAB
hatchit
ENTER
The first line
var hatchlineOffset = 1; determines the hatch density
hatchit.js
A quick cross hatch version:
crosshatchit.js
There is an older post about this. Existing Moi commands can do the work...
There are "algorithms" for it, and a couple of papers. I tried doing a script many months ago, with scanlines, so the
borders would alternate, but got bogged down with KD trees, etc. :-)
Applied to solids:
That's superb thank you!
I tried to find a previous thread about this but couldn't.
Maybe the "Dashed curve" script could be applied somehow to HatchIt.js ?
http://moi3d.com/forum/index.php?webtag=MOI&msg=6518.14
This discussion was a bit different from "hatch," and was for water jet etching.
http://moi3d.com/forum/index.php?webtag=MOI&msg=6218.1
I updated the HatchIt script.
You can now enter the hatch line spacing and choose a cross hatch option.
NOTE
The closed shapes must be drawn in the top view.
If you want to hatch several closed curves at once they must be all on the same Z plane.
HINT
You can hide all hatch lines In the Scene browser under Objects.
Or you can select and delete or color all hatch lines.
HatchIt.htm
HatchIt.js
I updated the script in the previous post with a live preview of the hatch lines.
Thanks Martin! :)
I updated the script in post 7279.9 again
http://moi3d.com/forum/index.php?webtag=MOI&msg=7279.9
Now you see a live preview of the
final result and you can also choose the hatch direction.
French version of the Hatch Fill is done ! :)
HatchIt.htm
HatchIt.js
Cool!
Un de moins! :)
et voilĂ ! ;)
http://moiscript.weebly.com/hachures.html
Pilou, c'est une modeste contribution au regard de ton investissement personnel !
Pilou, it's not to much against what you have done for Moi3D !
Is this a bridge to far or is it possible to create other Hatch Fills as attached jpg......would be very handy!
James Elliott
Hi James,
I guess it's possible, but would probably require quite a bit of work.
Someday I would like to have hatching and drafting type stuff set up directly in MoI but it will still be a while yet before I'll be able to focus on that.
I noticed that when I use my Hatchit script with V4 beta Nov-18-2017 the two check boxes are not showing.
<html>
<head>
</head>
<body class="commandbody">
<div id="TitleContainer" style="width:100%; text-align:center;">
<strong>Hatch selected objects</strong>
</div>
<div id="InputContainer" class="commandoptions" style="width:100%; padding-top:0.75em; padding-left:0.85em;">
Line spacing
<br>
<moi:DistanceInput id="offset" value="2">
<br>
<br>
<moi:CheckButton id="left_right" default="true">Left to right</moi:CheckButton>
<br>
<moi:CheckButton id="right_left" default="false">Right to left</moi:CheckButton>
<br>
</div>
<moi:CommandDoneCancel />
</body>
</html>
HatchIt.htm
HatchIt.js
Hi Martin, it's because your <moi:DistanceInput> control is not closed. V3 and V4 differ on how malformed HTML is processed, V3 would scan ahead and see there is no end tag found and then close off the tag. V4 I believe adheres to what is supposed to happen which is that it puts the content after your unclosed tag as children of it and doesn't close it off automatically at its origin point.
You can fix it and make it work in both V3 and V4 by closing that tag like this:
<moi:DistanceInput id="offset" value="2"/>
Lines 60 and 61 of .js are missing semicolons.
Runs on MoI4beta11_28_17 in top view, after making the 3 changes: / ; and ;
As a general question, is there some kind of 3rd party debugger or interpreter checker program?
Hi Brian, I haven't tried it myself but you might look at JSLint for JavaScript files. A checker for .htm files may be more problematic because it may say the custom moi: elements aren't standard and it also won't like that moi.css is implicitly added to every file.
re: semicolons - I believe semi-colons at the end of lines are officially optional in JavaScript so it should still run without those but it is good practice to have them.
2-21
22-37
