25-44
45-64
65-84
85-102
Unzipped everything, .livecode is in the same folder with the app bundle. When I click on the icon the GUI Builder Start screen pops up for a second then a message "A stack cannot be found" appears.
Try moving everything to your desktop and run there. It may be a permissions issue.
Tried that, same problem, it might be Sierra.
Ok. I'll check it out
Hi Neo,
Unfortunately, it must be Sierra. I still have El Capitan installed on my Mac and it works perfect there. Unfortunately, I don't have the time right now to update this Mac, but I will try a bit later on. I have a laptop I should go ahead and update and when I do I'll look into it.
I'd suggest making sure your protection allows for running non-signed apps and also that you have permissions to run it.
Please review below and make sure:
1. You have the correct file structure
2. You have correct permissions
https://altuit.cloud/web/dbpub/3D/MoiGuiConfig.png
Michael,
For some reason using syntax below no longer works. This keeps me from posting images using a URL (thus not bloating your forum).
<img src=https://altuit.cloud/web/dbpub/3D/MoiGuiConfig.png>
Hi Chipp, re: <img> tag, the src= attribute needs to have double quote characters around the URL, like this:
<img src="https://altuit.cloud/web/dbpub/3D/MoiGuiConfig.png">
Thanks. I thought I tried quotes as I know that's proper HTML, but before it worked w/out the quotes. Thanks!
Neo,
You might want to download the free LiveCode then just open the MoIGUI.livecode file and see if it doesn't work.
Once you open it, it should just 'play'-- no need to do anything else. I'd suggest V7 or V8.
Chipp,
Downloaded LiveCode v8 opens the file in edit mode does not run. How do you run the stack within LiveCode, is it by clicking on the play button? If so mine is ghosted.
Hello. Thanks to everyone who has contributed / is contributing to this GUI project. I really appreciate the efforts -- especially for a darker interface!
Hello Chipp, I am sure you're doing awesome.
I couldn't download the zip file from the link that you posted,
it keeps giving me an error. So, I got in touch with Michael
and he sent me the App. The App, unfortunately doesn't open.
'A stash cannot be found' is the message.
Can you please help? Thank you in advance.
Sandeep.
Just downloaded the guibuilder again, along with the latest livecode.org open source build.
The guibuilder exe works fine and the stack loads into livecode and runs live with no errors...
The download link in the initial post worked fine. Maybe you need to start with "why that didnt work for you"...
There was also an update to the stack downloaded to the initial download...
Probably a Mac permissions issue. They keep changing them. Sadly, I'm not in a position to rebuild the Mac version at this time.
Hello, I appreciate the advise.
I will look into this again and try to get to the bottom of your question.
Will keep you posted. Cheers.
S*
Thanks Chipp. Much appreciated.
S*
Is this application (and the Icon Builder application) still being supported?
I would like to get this application, but the links at the beginning of this thread seem to give me a warning that the site is not secure to visit.
Is there a safe/reliable way to get this and the Icon Builder for the Mac?
I have this issue as well. After taking the plunge and downloaded it when I run it, I get a: "A stack cannot be sound" error. Certainly don't want to be pushy, but I hope that Chipp Walters can find the bandwidth to make it so it works once again on the Mac, as it seems form watching some people on YouTube who have tweaked their UI, it can really polish the UI look and feel.
I realize that it is being greedy since this is a free app Chipp created, and he may not have the bandwidth (or whatever0 to deal with it currently. But it is a shame that we Mac users are left out int eh lurch for now.
Sorry, but I don't think it works on any platform at the moment. It hasn't been updated in quite a number of years and in fact I don't even have the program to aithor changes to it on my PC at the moment, nor do I have a Mac to test it on.
25-44
45-64
65-84
85-102
