6-25
26-45
46-65
66-68
Hi Brian, the inputs for Network go like this:
0: Object list - U curves
1: Object list - V curves
2: List of curve orientation values - U orientations, each has a "flipped" bool value and a "seam" parameter value.
3: List of curve orientation values - V orientations
4: String - Mode, one of "normal", "lighter", "custom", "uniform"
5: number - Custom tolerance, Fitting tolerance to use when mode = "custom"
6: int - Uniform Num Points, Number of interior points to use when mode = "uniform".
If you pile up all the curves in input 0 and leave input 1 blank and the orientation lists blank it will automatically sort the curves into separate U and V lists and generate the orientations.
Thank you very much Michael.
Separate u v inputs, availability seems nice.
Does this have any speed advantage?
I wonder a bit about what "List of curve orientation values means and how it works.
But probably do not need it.
Saw something about coons patch also...
Not much speed advantage, but if you already know which set a curve is supposed to be in if you separate them then you won't run the risk of the automatic sorter making a mistake in classifying them.
They will be created automatically for you if you leave it blank. It stores whether a curve should be flipped from its natural direction when used in the network and where the closing seam point of a closed curve should be switched to from its natural seam when used in the network.
A Coons patch is when you have just 4 boundary curves, there is an "exact" option that can be used in this case.
- MIchael
6-25
26-45
46-65
66-68
