13-32
33-52
53-68
Hi Max, re: offset
One problem there is that offset is one of the factories that does an "asynchronous" calculation - that's where it the work actually happens over on a separate moi_commandprocessor.exe process which is used for potentially long running calculations so the main UI does not just freeze while the long calculation is happening.
For async factories it is required that the objects that it use should be in the geometry database and not just a "loose object" which is what .calculate() returns back.
I'll try in v4 to remove this restriction, but for now if you put in moi.geometryDatabase.addObjects( output ); before doing the offset that will be one step that will be needed.
Then in addition to that there is another input that is required on the offset factory in order for it to work, which is the coordinate frame input. The various inputs on the offset factory are like this:
Offset inputs:
0 : object list - objects to offset
1 : number - distance to offset for distance mode, leave unset for "through point" mode.
2 : coordinate frame - point and coordinate frame for "through point" or "which-side" point for distance mode with curve offset
3 : string - corner type for curve offset either "sharp" or "round".
4 : boolean - Trim, true = trim curve results
5 : boolean - Flip, true = flip offset side (for solid/surface offsets not curve offsets)
6 : boolean - Both sides, true = offset curves to both sides
7 : boolean - Cap ends, true = add line segments between ends of open offsets.
Here's an offset example that works:
var factory = moi.command.createFactory( 'line' );
factory.setInput( 0, moi.vectorMath.createPoint( 3,1,0 ) );
factory.setInput( 1, moi.vectorMath.createPoint( 10,10,0 ) );
var output = factory.calculate();
var factory = moi.command.createFactory('offset'); //Calculating the offset of line
factory.setInput( 0, output);
factory.setInput( 1, 3 );
// Creates a coordinate frame with origin at 0,0,0 and with x/y axes along world x/y axis directions.
var frame = moi.vectorMath.createTopFrame();
factory.setInput( 2, frame );
factory.commit();
Thank you Michael.
Keep up the good work.
M.
Thank you for your TestNetwork script, that really helped me understanding.
But now I'm at the next thing.
`var objlist = moi.geometryDatabase.createObjectList();
objlist.addObject( linea );
objlist.addObject( lineb );
objlist.addObject( linec );
var factory = moi.command.createFactory( 'network' );
factory.setInput( 0, objlist );
factory.commit();
What does the 0 stand for?
I tried to make this script with 9 lines ergo 3 triangles with network command one triangle at a time, this only seems to work it the objlist is created new for each triangle, so for each triangle I have to make a new var objlist = moi.geometryDatabase.createObjectList();
Does the network always take the first three objekts in the list? Is there a way to empty the list so it is not necessary to recreate it?
Last question what exactly does factory.commit(); do? As far as I understand it makes MoI Display the network on the UI. I have recognized that it takes the computer some time to do the factory.commit(); for each network again and again. Can't I let the network command create the three networks and then do the factory.commit(); at the end to only update the ui once?
http://moi3d.com/forum/index.php?webtag=MOI&msg=3541.1
Hi dune1982,
It's the index number for which specific factory input to set.
Geometry factories can have various different inputs in them, they are in a list and when you call factory.setInput() that number tells it which of the different inputs you want to set for this particular call.
It uses whatever objects are put in the list - if it has 3 objects in the list it will use those 3 objects. If you have 11 objects in the list it will use those 11 objects.
Creating a list is not an expensive operations so there is no need to worry about avoiding creating one. The easiest way to get an empty list is to make a new one - you can remove objects from an object list by calling list.removeObject(obj); but you would need to loop through the object list and call this on each object in order to do it that way.
First it calls factory.update() automatically if it has not been called previously. factory.update() creates the new object and puts it in the geometryDatabase so that it can be seen. Also factory.update() deals with hiding any input objects if the factory is one that removes some existing object (like for example Transform > Move removes the original object being moved and creates a new moved object). If the command ends without factory.commit() being called these changes are reverted, with the newly added objects removed and the objects to be removed shown again. When you call factory.commit() it finalizes the factory's action and actually deletes the objects to be removed and will keep the newly created objects.
With a normal command, as you adjust various options factory.update() will be called so you can see the result on screen. Then at the end when the command is finished it called factory.commit() to make the last update stick. If the command is canceled in any way without .commit() ever being called any changes it made are reverted.
No, not with the regular factory.update() and factory.commit() mechanism, because that mechanism is oriented around the workflow of the regular Network command and there is no way in the regular Network command to build 3 networks in one shot.
But instead of calling update() and commit(), it is possible to use a different mechanism which is called factory.calculate() - if you call factory.calculate() it will return an object list of what the factory generates but it does not automatically put it in the geometry database like update/commit does, so you can then batch up the results and then call moi.geometryDatabase.addObjects( objectlist ); to add them in one shot.
Thank you Michael for explaining all this for me.
I had a look at
http://moi.maxsm.net/ because I wanted MoI to draw a cylinder.
I thought I had understood it, but it seems that I have not.
This is what I came up with:
`script:
var factory = moi.command.createFactory( 'cylinder' );
factory.setInput( 1, moi.vectorMath.createFrame() );
factory.setInput( 3, 20 );
factory.setInput( 5, 10 );
factory.commit();`
which ends with MoI drawing a circle.
I'm guessing that the frame is not set up?
So is your height zero?
I need to find the bits of scripting documentation I've saved in the past, put it together and organize it... :-)
As far as I understand it, factory.setInput( 5, 10 ); should give it a height of 10
Here's an example that works:
frame.origin = moi.vectorMath.createPoint( 0, 0, 0 );
factory.setInput( 1, frame );
factory.setInput( 3, 100 ); //diameter
factory.setInput( 4, moi.vectorMath.createPoint( 0, 0, 300 ) ); //length
factory.commit();
You must be more specific where you create the frame (Top, Bottom, Left ...) and you must give the factory two points for the cylinder direction not just the height.
-Martin
dune1982
You can't use input 5 without input 4 setting.
Check this two examples:
var radius = 10;
var height = 15;
var frame = moi.vectorMath.createFrame();
var direction = frame.evaluate( 0, 0, 1 );
factory.setInput( 3, radius );
factory.setInput( 4, direction );
factory.setInput( 5, height );
factory.commit();
var radius = 10;
var height = 15;
var direction = frame.evaluate( 0, 0, height );
factory.commit();
Thanks Max, frame.evaluate is cool.
Here's an explanation by Michael regarding the cylinder factory inputs:
For a cylinder there are 6 inputs:
0 = boolean value true = distance input is radius, false = distance input is diameter
1 = frame for cylinder bottom base point and axis directions
2 = point that defines the radius, this can be left out if a numeric radius is supplied instead
3 = numeric radius (or diameter) value.
4 = top point of the cylinder, this is required and also the orientation of the cylinder will be modified to point towards this point
5 = optional numeric height input, if this is supplied the cylinder will point towards the top point but will be this specific height instead of touching the top point
http://moi3d.com/forum/index.php?webtag=MOI&msg=5441.10
-Martin
Thank you so much Martin and MAX, this helped a lot understanding more and more. I wonder how you find these answers in the forum? everytime I use the search function it returns nothing interesting.
I hate to bother you guys again with my questions, I tried to figure it out by my self put didn't solve it.
I'm still learning the basics. So I made this script which should draw a polygon and then extrude it to 5
function drawpolygon() {
polygonfactory = moi.command.createFactory( 'polygon' );
var frame = moi.vectorMath.createFrame(); //erzeugt das Koordinatensystem für den Zylinder
frame.origin = moi.vectorMath.createPoint( 0, 0, 0 ); //Uhrsprungspunkt
var direction = frame.evaluate( 7.2, 0, 0 ); //Radius des Poligon
polygonfactory.setInput( 0, frame );
polygonfactory.setInput( 1, direction );
polygonfactory.setInput( 2, 6 );
polygonfactory.commit();
drawpolygon(); //until here It works, I see the polygon
var objects = moi.geometryDatabase.selectAll(); // the polygon is selected
var extrudefactory = moi.command.createFactory( 'extrude' );
extrudefactory.setInput( 0, objects ); //in my mind this should take the selected polygon to extrude
extrudefactory.setInput( 2, 5 ); // distance 5mm
extrudefactory.setInput( 3, moi.vectorMath.createPoint( 0, 0, 1 ) ); //direction to extrude
extrudefactory.setInput( 1, true ); //cap ends? yes
extrudefactory.commit();
Where is my mistake?
Hi dune1982, the problem is with this one line here:
The call to moi.geometryDatabase.selectAll() will select the polygon but it does not return an object list, it returns nothing so 'objects' does not have an object list like you were thinking it would.
Replace that line with these 2 and then your script should work:
var objects = moi.geometryDatabase.getSelectedObjects();
It may be better though to not use "select all" for grabbing the output because if you happen to have any other objects in the model before running this script it will select those as well.
You can instead grab an object list of the output from the polygon factory by calling polygonfactory.update() then polygonfactory.getCreatedObjects() before doing the polygonfactory.commit(). That way you won't need to use "SelectAll" as a way to gather the output.
So that would look like this:
polygonfactory.update();
var objects = polygonfactory.getCreatedObjects();
return objects;
var objects = drawpolygon(); //until here It works, I see the polygon
But anyway if you do want to use "select all" you'll need to gather the selected objects up using moi.geometry.getSelectedObjects() after you have the selection how you want, the call to moi.geometryDatabase.selectAll() does the selection but does not itself return the object list.
Hope this helps!
Thank you Michael, I think I'm understanding more and more.
Your reply
http://moi3d.com/forum/lmessages.php?webtag=MOI&msg=5461.10 helped me a lot understanding booleandiffrence. But if I run this script it looks fine at fist. But when I click on the resulting cylinder and move it, suddenly the result from the first booleandiffrence apears again.
Why is that?
Hi dune1982,
> first booleandiffrence apears again. Why is that?
Hmmm, I don't know why that would happen. I tried running that script over here and I can't seem to get the reappearing behavior to happen when I move the booleaned cylinder result.
Maybe you're seeing the result of a history update, what happens if you select everything and run Edit > History > "Disable update" button before trying to move the object does that make any difference?
Hello Michale
>Maybe you're seeing the result of a history update, what happens if you select everything and run Edit> History > "Disable update" button before trying to move the object does that make any difference?
Yes that helped after Disableing Update the result does not appear. What does that say now?
Thank you
Hi dune1982,
I guess it says that the effect you saw was due to a history update - there is a mechanism in MoI where if you edit an object, if it was one of the inputs that were used to generate some other object in the current model, the command that created it is basically re-run for you and the outputs regenerated. This can sometimes cause unexpected results if pieces were moved so that they do not intersect one another at all or things like that.
Hello
Everytime when I think: well now you know it. I seem to hit a script that I cant handle.
Today I'm trying to make a sweep:
var factory = moi.command.createFactory( 'sweep' );
factory.setInput( 0, triangle ); //is a objectList with three lines joined to a triangle
factory.setInput( 1, helix ); //is a objectList with a helix in it
factory.setInput( 2, ); //no idea what to set here
factory.setInput( 3, ); //no idea what to set here
factory.setInput( 4, 'none' );
factory.setInput( 5, 'flat' );
factory.setInput( 6, true );
factory.setInput( 7, true );
factory.setInput( 8, true );
// I stoped here as I have no and whant no scaling
factory.commit();
I only get a calculation failed out of this, i guess it is because auf 2 and 3 missing.
Hi dune1982, here are the inputs for sweep:
0 : ObjectList - Profile curves.
1 : ObjectList - Rail curves.
2 : Orientation List - List of IMoiCurveOrientation objects for profiles, for history updates leave empty on first run.
3 : Orientation List - List of IMoiCurveOrientation objects for rails, for history updates leave empty on first run.
4 : String - Point end mode, one of: 'none', 'pointystart', 'pointyend', or 'pointystartandend'
5 : String - twist type - 'freeform' or 'flat'
6 : Boolean - Maintain height true = maintain height for two-rail sweep (stretch profiles instead of uniformly scale).
7 : Boolean - cap ends true = do planar end caps.
8 : Boolean - Maintain tangent - true = use tangent preserving sweep if possible.
9 : Object - scaling rail - If set this defines a scaling curve.
10: String - Profile synch type - Options for synchronizing profiles: Auto, Exact, Refit, or NumPoints.
11: Int - Number of points to use for profile numpoints synchronization mode.
12: Point - "Flat direction" - Direction vector for twist=flat mode.
If you're still stuck could you post a complete script that has the other pieces like your helix and triangle curve being generated so I can run it over here and see what's wrong?
Pipe2 has some clues, and input 1 of factory.setInput( 1, WrapWithObjectList(rail) );
? Brian
13-32
33-52
53-68
