11-30
31-50
51-70
71-90
91-110
111-113
I realize that what I offer here is not a solution, but might something like this help to avoid jumping into the problems with parallel mode?
var vp = moi.ui.mainWindow.viewpanel.getViewport('3D');
if (vp.projection != 'Perspective')
vp.projection = 'Perspective';
moi.ui.alert('Projection set to "Perspective".');
return;
Might there be someway of asking the user for permission before switching the projection setting?
Hi Mindset,
I'm not sure how that would be done - there are multiple ways for it to get set, one of which is opening a file that had it set that way when it was saved... It would be difficult for a script to try and get involved with that since it happens right in the middle of the open process.
What a terrific software and community!!!
However, regarding message 7208.72 in reply to 7208.71, it is not clear what is opening...
Message 7208.71 was intended as inquiry about the Cycles script by Max Smirnov.
// Cycles v.0.98 - Max Smirnov. 2015
function Cycles()
var param = moi.command.getCommandLineParams(), exp=(param =='noexport')?false:true;
// Add this Block?
return;
// END Add this Block?
if ( param =='reset') { moi.ui.commandUI.resetPaths(); }
moi.ui.commandUI.Cycles(exp);
Cycles();
Seems the loink of the Standalone Cycles 64 bytes is not more accessible! ???
http://blender.dingto.org/cycles_standalone/Cycles_Windows64.zip
Someone has again this file on his computer ? Cycles_Windows64.zip
Thanks by advance! Because this process here is too hard for me!
http://wiki.blender.org/index.php/Dev:2.6/Source/Render/Cycles/Standalone
Many Thanks!
Cycles CUDA --> le fichier est corrompu :(
Si qqn a une version fonctionnelle ca m'interesse
Phil
J'avais récupéré une version fonctionnelle sur le site de Pilou :
http://moiscript.weebly.com/cycles-pour-moi.html
Bear17
Hi Max,
I've noticed from forum that you use Octan for rendering.
Don't you have similar script like MoI/Cyclec for Octan users by chance? :-)
http://render.otoy.com/forum/viewtopic.php?f=73&t=44688)
All good to you.
Mik
Hi Mik
Sorry, I didn't write such a script. I prefer to import obj manually.
The only script I wrote for Octane render is MoI scatter tool.
http://moi3d.com/forum/index.php?webtag=MOI&msg=6486.20
Thanks a lot, Max!
I import obj into Octane manually as well of course, no problem with it.
It was only idea to have some fusion of these great softwares :-)
Mik
Hi Max, I've just picked up this tread on the blog. Thanks.
I have installed the latest versions of Cycles and the script and all works fine and Cycles opens on running the _cycles script. The Cycles window is grey and blank but cycles is running. I have set the 3D view to 'perspective' and read the whole blog and cannot see a solution for this problem.
I am using a MS Surface Book on Windows 10.
Hi Matt
Are you using software or gpu cycles version?
Try this one:
http://moi.maxsm.net/media/files/Cycles.CPU.zip
I'm using Cycles.cpu
I tried the download you shared and still get the saame grey cycles window.
Will the script work with version 2 of Moi?.
I don't know, but most newer complex scripts need functions that are in version 3. You could give it a try though.
Thanks for the feedback Michael, appreciated!.
Hello Max, Michael and all,
because i could not find a binary for OS X on the net i compiled it myself two days ago.
I just want to let you know that it is vers. 1.7.0 standalone and your script seems no
longer compatible with it. Now Cycles requires <cycles> and </cycles> tags in the
.XML files. I also noticed that i have problems with the FOV parameters in the script
and with MoI. Once i completely omitted the FOV parameter in the .XML file, i got reasonably
render result.
Because i don't know if it was tested under OS X i like to ask if you or Michael, or
anybody else knows how to change the script so that it no longer writes in MoI's Temp
directory and how to start the Cycles program with your script under OS X.
Best regards
Here's a screen shot showing a test set-up without the FOV parameter usage in your script. With the FOV parameter i get when changing (for zoom-in) up-side down images for example.
Best regards
11-30
31-50
51-70
71-90
91-110
111-113
