2-21
22-41
42-61
62-81
82-101
102-113
Hey Scott
I may have found the problem....
It seems, I think, that this setting must be so: Options->View-> 3D view projection: Perspective
Yes. I noticed problems with parallel mode. At this moment I can't find a solution.
Max,
I sure that I can speak for everyone in thanking you for your contributions.
Thank you Max!
I had another problem in the beginning as well.
The "Orientation" for the OBJ export was set to Z-Up.
Eventually figured out that it should be set to Y-Up.
scott
Hi Scott,
I forgot about this MoI setting :) Thank you.
Fixed.
No problem Max.
Thank you.
hi... i am not able to download "Cycles Standalone", anybody know where i can find it?
http://moi.maxsm.net/media/files/Cycles.CPU.zip
http://moi.maxsm.net/media/files/Cycles.CUDA.zip
At this moment cpu version is more stable.
Cuda version has some problem with file saving. Waiting for update.
I realize that what I offer here is not a solution, but might something like this help to avoid jumping into the problems with parallel mode?
var vp = moi.ui.mainWindow.viewpanel.getViewport('3D');
if (vp.projection != 'Perspective')
vp.projection = 'Perspective';
moi.ui.alert('Projection set to "Perspective".');
return;
Might there be someway of asking the user for permission before switching the projection setting?
Hi Mindset,
I'm not sure how that would be done - there are multiple ways for it to get set, one of which is opening a file that had it set that way when it was saved... It would be difficult for a script to try and get involved with that since it happens right in the middle of the open process.
What a terrific software and community!!!
However, regarding message 7208.72 in reply to 7208.71, it is not clear what is opening...
Message 7208.71 was intended as inquiry about the Cycles script by Max Smirnov.
// Cycles v.0.98 - Max Smirnov. 2015
function Cycles()
var param = moi.command.getCommandLineParams(), exp=(param =='noexport')?false:true;
// Add this Block?
return;
// END Add this Block?
if ( param =='reset') { moi.ui.commandUI.resetPaths(); }
moi.ui.commandUI.Cycles(exp);
Cycles();
Seems the loink of the Standalone Cycles 64 bytes is not more accessible! ???
http://blender.dingto.org/cycles_standalone/Cycles_Windows64.zip
Someone has again this file on his computer ? Cycles_Windows64.zip
Thanks by advance! Because this process here is too hard for me!
http://wiki.blender.org/index.php/Dev:2.6/Source/Render/Cycles/Standalone
Many Thanks!
Cycles CUDA --> le fichier est corrompu :(
Si qqn a une version fonctionnelle ca m'interesse
Phil
J'avais récupéré une version fonctionnelle sur le site de Pilou :
http://moiscript.weebly.com/cycles-pour-moi.html
Bear17
Hi Max,
I've noticed from forum that you use Octan for rendering.
Don't you have similar script like MoI/Cyclec for Octan users by chance? :-)
http://render.otoy.com/forum/viewtopic.php?f=73&t=44688)
All good to you.
Mik
Hi Mik
Sorry, I didn't write such a script. I prefer to import obj manually.
The only script I wrote for Octane render is MoI scatter tool.
http://moi3d.com/forum/index.php?webtag=MOI&msg=6486.20
2-21
22-41
42-61
62-81
82-101
102-113
