6-25
26-45
46-65
66-85
106-113
Hi Max,
If you develop a bridge for Corona, from Moi ou Modo, i'll buy it in a second : )
Carlos
https://corona-renderer.com/blog/corona-alpha6-is-out/
cool...
But I don't see the standalone version ?
"Fully integrated into 3dsmax, standalone A6 version will follow"
but...
or there is something to do ?
https://corona-renderer.com/forum/index.php/topic,905.msg39557.html#msg39557
New standalone with extended timelock, working unitl 2016
https://www.dropbox.com/sh/kgzu0cqy903ygmb/AABiYJ9POECEmPAAUQLA7YHka/!Standalone/2014-09-15-extended%20timelock/fullspeed?dl=0
Ah ok! Thx!
Not at the target because some msvcp120.dll is missing on my computer! :)
Whishing install this one don't bring disagreament! :)
re: Not at the target because some msvcp120.dll is missing on my computer! :)
Try downloading and installing the "Visual C++ Redistributable Packages for Visual Studio 2013" from Microsoft, that should probably get you set up with msvcp120.dll on your machine:
http://www.microsoft.com/en-GB/download/details.aspx?id=40784
Thx for the info!
VIDEO
You purposefully tease us ;-)
Haha excellent,
I was investigating about the possibility to bridge modo render, but cycles sounds good enough !
Maybe it would be great to have an option to cycle between a couple of hdr environment (daylight, studio).
Very exciting news !
Well, well! Excellent! :)
The negative point is the Blender learning! :D
PS Does it transformation Nurbs -- Polys during the process ?
First public release of Cycles for MoI script
Installation:
- extract script archive into the MoI/commands directory
- download Cycles standalone (
http://blender.dingto.org/cycles_standalone/Cycles_Windows64.zip ) and extract it into MoI/cycles directory
- create MoI/snapshots directory
Script usage:
_Cycles -> export selected objects as cycles xml files, start Cycles
_Cycles noexport -> If you exported scene objects once, you don't need to export it every time when you run Cycles. This mode useful while changing camera position or material settings.
Materials:
Default material - Diffuse, Rougness 80%
You can change the material by editing the style name
Examples:
[D:20] = Diffuse, Rougness 20%
[G:20] = Glossy, Rougness 20%
[S:10] = Glass, Rougness 10%
[E:1000]= Emission, Strength 1000
Cycles hotkeys:
P - pause
Q - save image and quit
I - interactive mode
A futur hit!
Prodigious! Don't know that Cycles existing as Stanalone! (So no need to learn Blender! :D
Ah damned : don't works for me!
Just appear and disapear the Cycles Windows! (1/10 second ! ;)
No problem that Moi is in the (x86) folder and Cycles who seems a 64 bits program is inside this Moi's folder ?
What exactly the process ?
I launch Moi - I export an object as .xml ??? i have not that inside Moi !
I launch Cycles (?)
or other... ?
...must I install the last version of Blender too?
anyway it should works.
Does export window appears?
No, just install cycles standalone.
My script can have problems with special characters in the paths.. I'll check it tomorrow.
Just a Dos (?) window as I can see on this rapid view! :) and just 1/10 second then nothing!
What must be there in the Moi's Cycles folder ? All the unzip Cycles file ?
Ps It's a Zenit camera ? :)
http://wiki.blender.org/index.php/Dev:2.6/Source/Render/Cycles/Standalone
<< Cycles needs to be started from a terminal: cycles [options] file.xml
How have this terminal ?>> My script can have problems with special characters in the paths
(sure French Windows System alas has some accents... :)
Where is your script ???
I don't see it in your post!!!
http://moi3d.com/forum/index.php?webtag=MOI&msg=7208.16
Cycles.v.0.8.2015.02.06.zip -> moi directory/commands
Cycles_Windows64.zip -> moi directory/cycles
Yes :-) My first slr.
Hi, it's working very nicely. The exporter seems very stable and quick. Is there others options for materials?
Cool!
All works this time!
Frenchy Pilou what them you use for Windows? I saw that kind of windows before and I like them.
No Special Windows, it's the natural model by default in Windows 8! :)
(i just edit the color of 2D image for the forum ;)
But you can make the same inside Moi with editing color of the UI !
Options / View
French version and manual of Cycles for Moi
http://moiscript.weebly.com/cycles-pour-moi.html
6-25
26-45
46-65
66-85
106-113
