Full Version: Cycles for MoI
Show messages:  1-10  11-30  31-50  51-70  71-90  91-110  111-113
11 Feb 2015   [#51]
Question. Is there a way to set the render mode to GPU?
Max.
11 Feb 2015   [#52] In reply to [#50]
<< could you change thread name to "Cycles for MoI"? :)
Me I can't, but Michael yes! ;)
11 Feb 2015   [#53] In reply to [#51]
GPU rendering disabled in this build. I can't find the last build. Only sources.
11 Feb 2015   [#54]
Thx Michael for the Title's change! ;)
11 Feb 2015   [#55] In reply to [#54]
No problem Pilou! :)
15 Feb 2015   [#56] In reply to [#48]
When I use this to render the result is nothing like the view from which I started. Usually the render starts from within the model, so it only shows black.
Interactive mode is crazy difficult to line anything up and get a useful view.
How do you guys get such good results?
15 Feb 2015   [#57] In reply to [#56]
This script uses 3D view camera position. You need to set camera in 3D window and run the script.
15 Feb 2015   [#58] In reply to [#57]
Hi Max,
I just does not work that way for me...
Also, now with the version change it does not save to the output folder (or anywhere that I can find).
I have full rights to the MOI folder and below.
15 Feb 2015   [#59] In reply to [#58]
With the last version you don't need to put cycles in the moi directory.
Put cycles somewhere on your disk, create directory "output" in the cycles directory. The script will notice you if it can't find output directorу:)
http://moi3d.com/forum/index.php?webtag=MOI&msg=7208.48
16 Feb 2015   [#60] In reply to [#59]
Max,
I do very much appreciate all of the contributions that you and others have provided to the MOI community.
Hopefully I will be able someday to reciprocate or pay it forward in someway.
For now however, I continue to have the same problem with _Cycles.
I start in the 3d view, with everything visually set just the way that I'd like... but when _Cycles revs up, the view shown is from the inside of the model so no surfaces can be seen and hence nothing is discernable. When I try to adjust it in interactive mode, it winds up askew and tilted or exceedingly small.
I don't find a zoom in interactive mode... does it exist?
I hate to sound like I am complaining, especially since you have been so gracious to provide this and so much more!
It is actually quite to the contrary, it is because I like this feature SO VERY MUCH that I am frustrated at my failure to use it properly. It would definitely be a big time saver.
Maybe I could pay you some reasonable fee for a Skype lesson and get this going.
I don't imagine that it would take you very long to see whatever it is that I might be doing wrong.
I am in the Central Time zone, six hours behind Coordinated Universal Time, and my schedule is pretty flexible.
Once again, I thank you for all that you do.
Please let me know.
17 Feb 2015   [#61] In reply to [#60]
Hey Mindset,
It could just be that you need to zoom out a little bit.
Here is a snap of my test scene where the camera is far away
And here is one where I selected the three main objects and did a fit all "A"
Expand the 3D window, select the objects that you are interested in rendering and then hit the "A" key.
I've also attached my sample file so that you can use it to test on your system.
-scott
first.3dm
18 Feb 2015   [#62] In reply to [#61]
Hey Scott
I may have found the problem....
It seems, I think, that this setting must be so: Options->View-> 3D view projection: Perspective
18 Feb 2015   [#63] In reply to [#62]
Yes. I noticed problems with parallel mode. At this moment I can't find a solution.
18 Feb 2015   [#64] In reply to [#63]
Max,
I sure that I can speak for everyone in thanking you for your contributions.
Thank you Max!
18 Feb 2015   [#65]
I had another problem in the beginning as well.
The "Orientation" for the OBJ export was set to Z-Up.
Eventually figured out that it should be set to Y-Up.
scott
19 Feb 2015   [#66] In reply to [#65]
Hi Scott,
I forgot about this MoI setting :) Thank you.
Fixed.
19 Feb 2015   [#67] In reply to [#66]
No problem Max.
Thank you.
3 Mar 2015   [#68]
hi... i am not able to download "Cycles Standalone", anybody know where i can find it?
3 Mar 2015   [#69] In reply to [#68]
http://moi.maxsm.net/media/files/Cycles.CPU.zip
http://moi.maxsm.net/media/files/Cycles.CUDA.zip
At this moment cpu version is more stable.
Cuda version has some problem with file saving. Waiting for update.
4 Mar 2015   [#70] In reply to [#69]
