20-39
40-59
60-79
80-99
100-113
<< pressing Q to save and quit from Cycles, Win8 reports Cycles had terminated incorrectly and was searching for a solution
Idem for the Q key !
Hi PILOU
Sorry, I don't understand: What is "Idem"?
Fake Pilot
>>But not a programmer, so didn't understand how to edit your script so it does this automatically.
Wait for a new version which supports manual folder settings.
Frenchy Pilou
>>Can we imagine have some cursors in Moi for input the Different shaders against input them by hands?
Not now.
hairykiwi
Try to run MoI with administrator rights. Your Program files/MoI/.. folder is write protected.
It will be better if you'll wait for the new version. With this version you can move cycles and snapshots folders everywere you want.
Hi :)
idem is a latin word that means : "the same of "
@Pilou
means: " same thing for " Q key
M
Max, thanks.
I tried running Cycles as admin, but not MoI - I'll give it a go. In any case, a snapshots folder outside the Program Files folder is much more preferable - looking forward to that, thank you.
Mauro,
Doh! Sometimes, even when seemingly hard-wired to the net, I overlook using a search engine to make up for my poor language skills. Thanks for educating.
Here's a bit of trivia: rather coincidentally, while I was learning/working on a MoI script earlier today, I thought, 'Where does the word 'factory' actually come from?" Searching for "factory etymology" shows the Latin
factorium is literally, ‘oil press’; the English language makes more and more sense all the time, after discovering its roots. :)
version 0.98 :)
Added:
[TR] - transparent shader
[CH] - checker texture
Default material changed to [V:100] Velvet
Increased default background brightness
Now script stores location of the cycles.exe in the moi.ini. You need manually choose a location of the cycles.exe.
Also you need to create "output" subdirectory in the cycles directory.
Use "_cycles reset" command to reset script settings.
French Manual Updated :)
http://moiscript.weebly.com/cycles-pour-moi.html
And what about Textures ?
Cool stuff!!! thanks for posting.
Finally, v.1.0
Optimized emission styles export.
Pilou, this script is good for beginners, and maybe for fast(test) rendering. But I don't see any reason to make a material library in the MoI or textures support.
There are many good render programs which do it much better.
No problem! :)
Pilou, could you change thread name to "Cycles for MoI"? :)
Question. Is there a way to set the render mode to GPU?
Max.
<< could you change thread name to "Cycles for MoI"? :)
Me I can't, but Michael yes! ;)
GPU rendering disabled in this build. I can't find the last build. Only sources.
Thx Michael for the Title's change! ;)
No problem Pilou! :)
When I use this to render the result is nothing like the view from which I started. Usually the render starts from within the model, so it only shows black.
Interactive mode is crazy difficult to line anything up and get a useful view.
How do you guys get such good results?
This script uses 3D view camera position. You need to set camera in 3D window and run the script.
Hi Max,
I just does not work that way for me...
Also, now with the version change it does not save to the output folder (or anywhere that I can find).
I have full rights to the MOI folder and below.
With the last version you don't need to put cycles in the moi directory.
Put cycles somewhere on your disk, create directory "output" in the cycles directory. The script will notice you if it can't find output directorу:)
http://moi3d.com/forum/index.php?webtag=MOI&msg=7208.48
20-39
40-59
60-79
80-99
100-113
