17-36
37-56
57-76
77-96
97-113
What's the way to process ball_square_scene.xml
Can we imagine have some cursors in Moi for input the Different shaders against input them by hands?
And what about textures ?
Very nice work Max! Thank you very much! :)
I had a few problems, described below, which might be a bug with the MoI script - and/or help someone else.
A big problem remains however: Cycles still isn't writing the png image to the snapshots folder despite reporting that it is, (see the screen capture below). Any ideas appreciated.
My Win7(64) was reporting compatibility issues:
- The first script didn't work, other than the Cycles window flashing open-closed after I specified the mesh geometry in MoI.
- The second script seemed to work for a while, then, after pressing Q to save and quit from Cycles, Win7 reports Cycles had terminated incorrectly and was searching for a solution; nothing saved either.
- Next time Cycles started, Win7 told me it was applying compatibility settings.
- Thereafter, pressing Q in Cycles displays a message saying it's saving the png in the MoI3.0\snapshots folder, but no file is actually saved there.
- Now I'm right back to the beginning - the Cycles window flashes open and closed after specifying the mesh geometry.
Somewhere along the way (above) I changed the script to "Cycles noexport". At first it seemed to work, then in the Cycles window that flashed open-closed, I could read "xml file not found" or words to that effect. Changing the script back to "Cycles" got it working again.
Cycles reports "Writing Image", but no file is created:
Cheers,
hairykiwi
<< pressing Q to save and quit from Cycles, Win8 reports Cycles had terminated incorrectly and was searching for a solution
Idem for the Q key !
Hi PILOU
Sorry, I don't understand: What is "Idem"?
Fake Pilot
>>But not a programmer, so didn't understand how to edit your script so it does this automatically.
Wait for a new version which supports manual folder settings.
Frenchy Pilou
Not now.
hairykiwi
Try to run MoI with administrator rights. Your Program files/MoI/.. folder is write protected.
It will be better if you'll wait for the new version. With this version you can move cycles and snapshots folders everywere you want.
Hi :)
idem is a latin word that means : "the same of "
@Pilou
means: " same thing for " Q key
M
Max, thanks.
I tried running Cycles as admin, but not MoI - I'll give it a go. In any case, a snapshots folder outside the Program Files folder is much more preferable - looking forward to that, thank you.
Mauro,
Doh! Sometimes, even when seemingly hard-wired to the net, I overlook using a search engine to make up for my poor language skills. Thanks for educating.
Here's a bit of trivia: rather coincidentally, while I was learning/working on a MoI script earlier today, I thought, 'Where does the word 'factory' actually come from?" Searching for "factory etymology" shows the Latin
factorium is literally, ‘oil press’; the English language makes more and more sense all the time, after discovering its roots. :)
version 0.98 :)
Added:
[TR] - transparent shader
[CH] - checker texture
Default material changed to [V:100] Velvet
Increased default background brightness
Now script stores location of the cycles.exe in the moi.ini. You need manually choose a location of the cycles.exe.
Also you need to create "output" subdirectory in the cycles directory.
Use "_cycles reset" command to reset script settings.
French Manual Updated :)
http://moiscript.weebly.com/cycles-pour-moi.html
And what about Textures ?
Cool stuff!!! thanks for posting.
Finally, v.1.0
Optimized emission styles export.
Pilou, this script is good for beginners, and maybe for fast(test) rendering. But I don't see any reason to make a material library in the MoI or textures support.
There are many good render programs which do it much better.
No problem! :)
Pilou, could you change thread name to "Cycles for MoI"? :)
Question. Is there a way to set the render mode to GPU?
Max.
<< could you change thread name to "Cycles for MoI"? :)
Me I can't, but Michael yes! ;)
GPU rendering disabled in this build. I can't find the last build. Only sources.
Thx Michael for the Title's change! ;)
No problem Pilou! :)
When I use this to render the result is nothing like the view from which I started. Usually the render starts from within the model, so it only shows black.
Interactive mode is crazy difficult to line anything up and get a useful view.
How do you guys get such good results?
17-36
37-56
57-76
77-96
97-113
