11-30
31-50
51-70
71-90
91-110
111-130
131-150
191-198
Voronoi.v.0.98
http://moi.maxsm.net/item/48
French version! ;)
http://moiscript.weebly.com/scripts-de-max-smirnov.html
Thanks a lot Max !
Thanks Max
Always funny!
how???
Very very nice!
<< how???
_Voronoi
Extrude "Tapered"
Flow on a Sphere
Render in free Real Time SimLab Composer Lite (max 1920 * 1080)
Have fun!
Here Corners of Voronoi are >90 so rounded (put 0 if you want sharp forms)
Voronoi.v.1.0.2018.03.05
Changed random algorithm.
Fixed bugs.
Thank you very much for your constant developing!!
Voronoi script is a extremely useful tools to create very different kinds of geometric CG!
I'm experimenting some cool stuff with Moi + Voronoi and iPad Pro.
With the new _Voronoi by Max Smirnov:)
Take 2 sets and use the ISect Boolean Function! ( whith Union Sets disabled )
then ExplodeMove hidden function
Have fun!
Here twice the same but you can take any things! :)
PS French Version Updated!
thanks!
Hello Max and everyone.
I had some fun with your Voronoi and the iPad Pro (Affinity Photo, PixelMator, Procreate 4, Snapseed).
Ciao!
Marco (mkdm)
almost perfect! the last issue is sharp corners even when smooth is 100%
it's actually no issue... MoI has all the tools to get the desired results.
You can't expect that a script always does all the work for you!
Hi Stefan!
@You : "...You can't expect that a script always does all the work for you!..."
I completely agree :)
The "manual stage" it's always necessary and, I would say, mandatory.
I agree.
Hi Marco,
years ago I drawn Voronoi with ballpen. so, you can't blame me - I already made a lot of "manual stage" and I can't see any problems if script makes a same job in better way.
Nobody is blaming you, even if it may sounded like that.
Like i said, i would not expect that a script does always everything for me
and i know also that i can't put in here permanent requests to programmers
to add this and that in their free scripts, in their spare time. Be happy what
you have and since you know how to do it manually, simply do it. :-)
now you're teaching me...
11-30
31-50
51-70
71-90
91-110
111-130
131-150
191-198
