9-28
29-48
49-68
69-88
569-574
I've been an enthusiastic MoI user since the first version went up for sale.
I have only one wish - improved fillets.
Why only one wish? Because I think this is so fundamental to building models that any other new features, IMHO, are adding minimal value.
I agree with PaQ - I would pay more to get a better fillet kernel. Using two programs is not an option I even want to consider.
Ed
@sandykoufax, re:
> My wish for V4 is Diagnostic tool for joined surface to make solid.
> I'd like to make my model to solid, but sometimes it has result in joined surface.
> So I want to know which faces have problem.
For now the "Select naked edges" script can help with this, once you set it up you can then push the N key on the keyboard to make naked edges in the model get selected so you can see where the problem areas are at.
There's some info on how to set it up here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6051.2
oh! I have to try later. thanks!!
Hi Michael ..
Again ... I would sure like to see dimensions and line widths and a way to print finished 2d drawings ... and yes, I am aware that I can use other software to do this phase of my work but it sure would be nice to simply stay in MoI.
Great work with Ver 3 ... thanks again. MoI is my most favorite program for architectural design and 3d modeling.
eric
I think that Michael Gibson need a little time to relax, with a glass of wine, beer, soda or juice (depend of his preference)
everybody enjoy version 3, find bugs, reported back to michael and AFTER that we can start thinking about version 4
please! everybody start making models in moi3d v3 right now!
post it in every 3d forum, facebook, twitter, etc
Is time to help sell this little gem and help Michael with some revenue, don't you think?
peace and have fun modelling!!
Leo
Nested grouping
Surface editing additions (We've got add points. Need remove points and neighbor matching/continuity options) This equates to beefing up Nsided, network and blend....
A "surface" fit option to ImportPointFile command
MoI's implementation of the command/object manager.
The Extended properties panel and Options (Various inspection and analysis)
Deeper history. As a start, possibly a stored text of the operations list (simple or advanced option). Doesn't need to be embedded.....
A circular plane tool under the solids creation menu
Beef up LoadView and SaveView incorporating ScreenCapture into it....
Hello,
Perhaps some additional curve tools. One I've found helpful is to be able to dynamically change the start and end point of a blend curve along the set of matching curves, not just starting and ending the curve at the end points of the curves to be blended.
Peace on Earth.
I would like to see a Join command, I ask for Flow command awhile ago (
http://moi3d.com/forum/index.php?webtag=MOI&msg=1760.1) and you did it, so I am hoping this might be add in the future. Making things watertight is still a long process for me.
Hi Tom, re: Join command - there is a Join command in MoI currently, you can find it under Edit > Join :
@Danny,
Went straight for the whole enchilada!
Although, i think it's acheivable with MoI!!!
@ Burr, Yeah, I think if everyone in the world used MoI it'll be a very peaceful place to live :)
I'm sorry, but I didn't find any newer feature suggestion thread for v4.
Anyways, I'd like to see an option for a color axes cross in the viewports. Something like that:
Hi 3image,
It's possible to set that in the moi.ini file. To do that, go to Options > General > "Edit .ini file" button, and inside the moi.ini file under the [View] section are the following 3 r,g,b color values:
[View]
AxisIconXColor=160,160,160
AxisIconYColor=160,160,160
AxisIconZColor=160,160,160
Each channel can contain a value between 0 to 255.
Actually, this is very neat. Didn't know that. Thanks! :-)
Something I always wanted to see in cad and modelling packages is user defined reference points that stay attached to the model, for example a plate with 3 holes and each one having a reference point at it's center and when you hover over the reference point you can rotate the object around that point which is also a big aid if you come to animating the model. Degrees of rotation could also be allocated to a reference point.
Hi Michael, for the time being you can create your own reference points using the Draw curve > more > Point command.
They are their own individual objects though, if you want them to move with your model you would need to make sure they are selected along with your object so they get transformed with it.
From Bear 17
- Incorporate import OBJ / STL directly in the basic program (not script) and optimize NURBS interpolation from Polygonal
- Component Management Object Library + component (we can dream!)
- Improvement fillets for the complex shapes
- Integrated management features for editing shots (dashed / dotted lines, thick lines ...)
- Assign a texture (jpg, gif or png) instead of a color. This texture may have a sliding scale / adjustable.
- Record the position of a 3D camera view and be able to find or copy it to another file.
- Register the camera back level on the views above / right / front and you can find it or copy it to another file.
- Have an indicator on the screen to indicate collision objects
- Open up a platform for the exchange and 3DM file storage, accessible directly in Moi3D
- A viewer font / character in Moi3D. For example, if I want to use the font / font wingding "phone icon" ...
The problem is that we must identify the characters in Word and do it under analogism Moi3D
- Make it compatible formatting Excel spreadsheets by copy / paste between two programs (to make a plan cartridge for example)
- automatic tracer lines/curves from image 2D JPG PNG...
Hi Pilou, wow those are a lot of great wishes, but unfortunately many of them would involve a large amount of work and are probably outside of the scope of what MoI is focused on doing, please remind Bear 17 that it's a focus for MoI to be a simple and easy to use modeling program... Things like a connection to Excel don't really fit within that focus.
A few of those may be possible at some point though.
Maybe more of them could come in the future as plug-ins though.
Hello Michael ,
I prefer to give ideas without setting limits. We must sort the ideas. it remains wishes, only wishes.
I understand that Moi3D must remain simple to use, while providing maximum opportunity. It's a delicate balance.
Moi3D is the only software I have that correctly uses the "touch " my tablet. The V3 is already powerful and indispensable (with Pilou's support !)
- Bear17
9-28
29-48
49-68
69-88
569-574
