Full Version: V4 Wish List
Show messages:  1-3  4-23  24-43  44-63  64-83  84-103  104-123  124-143  …  564-574
27 Jul 2016   [#64] In reply to [#63]
1/ Unfold / Flatten tool ( Unfold curved surface capabalities )
2/ Export dimension tool
27 Jul 2016   [#65] In reply to [#64]
Hi Dzeko, re: #1 unfolding, unfortunately unrolling surfaces is a quite complex area of work because it's not mathematically possible to unroll just any curved surface to a flat sheet without stretching things, that's only physically possible with a special category of curved surfaces called "developable surfaces".
Surfaces in MoI are not restricted to only be constructed as developable surfaces, so it would be kind of weird to have an unfold surface tool which didn't work on most things that you constructed in MoI, there would probably need to be a whole set of special developable surface construction and analysis tools in order for that to really make sense, but that makes this a quite complex intertwined set of specialized features which is unlikely to happen in MoI anytime soon.
Rhino does have some of those tools though, if you need surface unrolling now you can use Rhino in combination with MoI to do it.
27 Jul 2016   [#66] In reply to [#65]
thank you for explanation M.G
i talk more about a very simple flatten surface.
27 Jul 2016   [#67]
You have FormZ Free for Unfold! ;)
Minute 24.10
27 Jul 2016   [#68] In reply to [#66]
Hi Dzeko,
What is the end goal of your simple flattening - something like making paper cutouts? Rolling sheet metal to make metal panels? Or something different?
Message 6925.69 was deleted
27 Jul 2016   [#70] In reply to [#68]
yes like the unfold from form-z
for now i export in .obj and realize this task in the last mentioned
and make me nervous that i have to go out of Moi for this task...
( i create some metalic profil,( surface works good no need solid ) and flat this, for show is flat developement ( for cutting in reel ).
27 Jul 2016   [#71] In reply to [#70]
Hi Dzeko, so in your post you wrote "( Unfold curved surface capabalities )" where I took special notice that you used the word "curved".
But your example (deleted now?) has only all flat surfaces and not any curved ones...
Are you looking for something that would unfold only objects made up of all planar surfaces? Something like that could probably be done as a plug-in at some point in time, maybe not quite yet but maybe when a few more things are added to the script interface layer it could be possible.
13 Sep 2016   [#72]
Hello Michael Gibson,
I have a V4 Wish:
Would it be possible to export a curve as a motion path via FXB (or elsewise)?
If so, might it be reasonable to do so from a script even while we await V4?
Of course, I do not know what would be involved in such a request... but it would be an EXTREMELY useful capability.
Again, thank you for all the good work that you do.
I am a real fan.
-- Mindset
13 Sep 2016   [#73] In reply to [#72]
Hi Mindset, I'll see what can be done in v4, you might mention it again once v4 betas are underway.
I don't think it will be feasible to do from a script, scripting does not currently have access to all the low level details of the curve structure.
In the meantime, Moi can currently export curves to 3DM, SAT, STEP, IGES, and DXF formats so see if your target software supports reading any of those. You can also export curves to SKP format as well although they'll get turned into polylines.
13 Sep 2016   [#74] In reply to [#72]
FXB is some kind of music file (?)
So do you mean FBX?
https://en.wikipedia.org/wiki/FBX
14 Sep 2016   [#75] In reply to [#74]
Oops, yes... need to export curves as motion paths via FBX.
Apparently FXB is, by contrast, is an Archipelago Exchange stock symbol for Guggenheim CurrencyShares British.
So, an honest mistake on my part.
-- Mindset
28 Sep 2016   [#76] In reply to [#51]
Seems that my request for multi-segment marquee selection tool was answered by http://moi3d.com/forum/index.php?webtag=MOI&msg=8088.5
Have not really tried it yet... but...
WOW! Thank you Michael Gibson!!!
Best software community ever! Moi3d!
3 Oct 2016   [#77]
Will to make a 3D and 2D dimensional grid of the Golden ratio for the different dimensions of metric and inch, and a custom sizes like the Russian fathoms? Such as in SketchUp or Vectorworks. For example as the Atrise GoldenSection or PhiMatrix Golden Ratio Design for a building structure.
3 Oct 2016   [#78] In reply to [#77]
Hi Vlad, it's a big goal to keep MoI simple and uncluttered, and so I'm sorry but it's not too likely to get these particular functions built in.
But you can use existing functionality to set them up now - for example if you set up a gridwork of line objects arranged in Golden ratio sections like you want, you can then use the Edit > Lock function to lock those lines so they will not be selectable but remain snappable and you can then use them for reference.
For Russian fathoms units, I'd recommend just leaving the unit system set to the generic "No unit system" and then just consider the units to be whatever you wish.
Thanks, - Michael
3 Oct 2016   [#79]
I never paid attention to the Edit > Lock function before. Very useful. Learn something new every day!
4 Oct 2016   [#80] In reply to [#78]
Hi Michael, thanks for the tips)
5 Oct 2016   [#81]
Hello Michael, and good morning.
What about Instancing on V4 ? Are you still working on that ?
Thanks.
5 Oct 2016   [#82] In reply to [#81]
Hi Marco, I haven't had a chance to work on instancing for v4 yet, but it is high on the list of what I'd like to get done.
Probably the first v4 beta won't have any new features in it other than being 64-bit and a Mac native build, then once it looks like that big transition is stabilized I'll work on some new features on top of that. Dimensioning, instancing, and grouping are all high on the list of what I'd like to do but I cannot 100% promise exactly what will get in for v4 as of yet.
5 Oct 2016   [#83] In reply to [#82]
and thanks for the good news.
I agree with you regarding your to-do list and also for your primary target, that is the stabilization of the 64 bit transition.
Dimensioning, instancing, and grouping are all absolutely "wanted dead or alive"!
With that said, I don't know if someone has already asked, but it would be really a great improvement if you could give better "surface-continuity" tools
to the new Moi.
I'm speaking of nothing so complex, but just two fundamental things :
1) at least G3 and G4 continuity for blend tool
2) Some simple visual checker for surface continuity. It would be sufficient to have Zebra stripes like Rhino.
Best wishes for your job and have a nice day.
