505-524
525-544
545-564
565-574
My bad - I wrongly assumed that seeing 01, 02, 03 that it was limited to 2 digits.
So could you have an entry in the INI file that specified the format of the suffix?
Nothing fancy, perhaps just allowing for letters and a place holder character for the digits.
For example an entry of " v0000" would append " v0001" , " v0002 ", " v0003", etc (without the quotes of course).
But your idea of using the end of the first file name I create would work as well - but it requires me to remember to do it - which, at my age, may or may not happen. ;)
Thanks.
Frederick
Hi Frederick, I've set it up using the method of preserving existing padding.
If you forget there isn't much consequence, it will still save.
So if I create the first file and it ends in " v0001" the next incremental save would end in " v0002"?
Frederick
Hi Frederick,
Yes, in the next v4 beta that's how it will work.
I am now a happy camper!
Thanks much.
Frederick
Hello Michael,
Hmm... Maybe I missed something.
Does the Detail button not provide the opportunity to copy the value of a Dimension?
Is the value of the decimal precision property preset (Options / Dimensions / Formatting / Decimal display) available for read access via the API anywhere? Thanks.
--Larry
Hi Mindset, re:
It does not, but that is a good idea to put in.
Hi Larry,
Yup, you can get a list of annotation presets using moi.geometryDatabase.getAnnotationPresets(); , and then each preset object has a whole bunch of properties on it:
presetName
presetIndex (read-only, position in preset list)
setFont() (function that will show font picker dialog)
fontName
fontPtSize
fontStyleName
fontWeight
fontStyle
fontUnderline
fontStrikeout
textDisplayMode
textAlign
scaleMode
height
textAnchor
textBoxOutline
textBoxOutlineWidth
textBoxOutlineWidthModelUnits
textBoxPaddingX
textBoxPaddingY
textBoxPaddingXModelUnits
textBoxPaddingYModelUnits
arrowheadType
arrowheadArrowLength
arrowheadArrowLengthModelUnits
arrowheadArrowWidthFactor
arrowheadOpenArrowLength
arrowheadOpenArrowLengthModelUnits
arrowheadOpenArrowWidthFactor
arrowheadTickLength
arrowheadTickLengthModelUnits
arrowheadTickLineWidth
arrowheadDotSize
arrowheadDotSizeModelUnits
arrowheadReverse
arrowPosition
outsideLineLength
outsideLineLengthModelUnits
outsideDrawLineAcross
extensionLength
extensionLengthModelUnits
extensionGap
extensionGapModelUnits
arrowLineExtension
arrowLineExtensionModelUnits
formattingDistanceDisplay
formattingFractionalPrecision
formattingDecimalPrecision
formattingDecimalShowTrailingZeros
radialDimensionRadialType
radialDimensionCrossSize
radialDimensionCrossSizeModelUnits
The one for Formatting > Decimal display is the formattingDecimalPrecision property, it can be an integer number from 0 to 7 for the number of decimal places to show.
Awesome Michael, you've thought of everything!! I'll give it a whirl.
--Larry
505-524
525-544
545-564
565-574
