323-342
343-362
363-382
383-402
403-422
423-442
443-462
563-574
Thank You, Michael, good to know. I wasn't aware of that feature yet ;).
Paul
Hi Michael. Thanks for the bug fix, everything works perfectly. I have a question, you can add in the program approximation of the curve by arcs and lines. Or is it difficult?
Vladimir.
Hi Vladimir, I'm not really sure how difficult an arc fitting mechanism is, I've never made one before. Is it important for it to use the least number of arcs possible?
Let this controls the accuracy. You can mix lines and arcs.
Vladimir.
google of "biarc approximation of nurbs curves" gets some hits...
- B
Hello Michael. I'm sorry if I wrote somewhere bad, I communicate through an interpreter. If the translation is bad let me know and I will cease to bother you.
Vladimir.
Hi Vladimir, you didn't write anything bad I'm just not sure how much work is involved and I'd need to do some studying before really knowing any answer for when an arc fitting function could be implemented.
I was also trying to think about where it could be exposed in the UI, there are a few different possibilities like maybe on a more detailed object properties dialog, or maybe as another curve conversion option for DXF export.
Thank you for your attention. Good luck to you.
Here is a link to a recent paper, with an algorithm, for fitting arc splines to NURBS:
https://www.researchgate.net/profile/Xunnian_Yang/publication/3845146_Approximating_NURBS_curves_by_arc_splines/links/594ca7eb458515e70348b782/Approximating-NURBS-curves-by-arc-splines.pdf
Thanks Brian!
Message 6925.393 was deleted
You are welcome Michael.
I'm still reading the paper...
From my limited understanding, the purpose of such a dxf export in arc/line format would be useful?
Maybe tangents of NURBS curve would be exposed to scripting in the future?
- B
A closer look shows that the paper was uploaded in 2017, but was written in 2000.
There are 2 other similar papers by the author in ~2001, and the paper is cited by other papers.
Piegl & Tiller:
https://documents.tips/documents/biarc-approximation-of-nurbs-curves.html
- B
Yeah often time research papers can take a lot of effort just to read and understand.
Yes, there are some CNC machines that need to be driven only by arcs for curved pieces and don't deal with spline curves.
I'll see if I can cook up some initial curve evaluating methods for the next beta.
Thank you Michael.
Maybe I'll start a new biarc thread.
There is a lot of information on the web.
a HUUUHGE wishlist ! obj importer as reference ! similar to Topogun (for Michael ref
https://youtu.be/_SOCEnTgSns?t=2m21s )!
where i should have my base Hpoly as reference for modeling, some snaps options to draw curves on Hpoly !
i'm not talking about the scripted one that Max did ! (it's making surfaces out of polys - where a poly converted to surface is 16 larger than it should be ->4*4 conversion for a poly) & it's slow, Hpoly wont support, only LP
where it can be used !
*scanned surfaces to draw on top of them
*from zbrush sketches to moi - lot's of users will enjoy it ! since poly modelling is Huge time consuming -> will speed up process *4 or more
*there are more obj (meshes) libraries than stl ones !
*u'r stuff :))
- Anti-shell. Instead of shelling out a part, be able to unshell it, essentially making the interior of a part a solid.
- An easier stl import flow. I realize from my earlier posting on the subject that stl import isn't directly supported, but there seem to be workarounds, nothing perfect, but doable (like going through the nodeditor, which I still can't understand or make work, dummy me). I'd love to see something like this incorporated into the next version.
- Parametric MOI!
Hi Cemortan_Tudor, and Bob - these are pretty different kinds of things than what MoI is really focused on doing.
@Cemortan_Tudor - Reverse engineering really needs a specialized toolset to do it well. It's a broad area of work that MoI is just not focused on.
@ Bob -
re: anti-shell, could you post an example?
re: An easier stl import flow - as I mentioned in that other thread, STL files contain triangle mesh geometry, it's a very different type of geometry than the NURBS surface geometry that MoI is focused on working with for modeling. It's also a broad area of work that is pretty different than what MoI is focused on right now.
Any chance of adding a angle tool under deformations? If you could simply pick faces then pick the axis to taper from this would really be helpful for making master patterns for casting or models for injection molding.
Right now we are limited to the basic draft from the extrusion tool which is handy for text models but limited to base curves. Often I have models that require more than just a simple extrusion where drafts need to be put in place or modified after creation of the part as features are added. I usually end up extracting curves, offsetting them and lofting them back to create my solids which can be horribly tedious especially when you know the customer is going to make a change for the sake of changing...
Hi KAC - do you have an example you could post? It can be difficult for a deformation to process just some faces and not others.
323-342
343-362
363-382
383-402
403-422
423-442
443-462
563-574
