208-227
228-247
248-267
268-287
288-307
308-327
328-347
568-574
NICE!
Hello Michael,
is it possible to add in a scaling option that can be set to reduce the amount of scale from farther away in version 4, like a taper effect? Or possibly being able to control the extrude by also adding an option to extrude less when farther away from the point of extrusion if selected. Another 1 it would be very cool once setting up a lined section if you could possibly hit a button that says all corner section turn into a 90 degree rounded instead of hard edge. Just some ideas that would save a lot of time when modeling. If you need more details on this I will show some examples of what I mean.
Take care.
Hi 3DFanatic,
I do want to add in a "Cage edit" type deformation command which could be used for tapering. Right now I'm not sure when it will happen though - hopefully in v4.
There is a tapered extrusion option in the current version already, you activate it by pushing this button in the Extrude command:
You can use the Construct > Fillet command to do that- if you have a polyline like this:
Select it and run the Construct > Fillet command. Points will be displayed on the corner and the prompt will read "Select corners or push done to do all". If you only want to round off some corners, select those and right click. If you want to do all corners just right click.
Then set a radius and smooth arc pieces will be put into those corner areas:
If those don't do what you were asking about then yes please post an example.
Thanks for all that great information this will help me progress thanks. Also thanks for the consideration on the scaling
For V4 what about the inclusion of a Mirror Plane which doesnt actually create mirror parts just mirror visual for a live modelling aid when happy with model create an actual mirror - I know history sort of does this but gets broken when you start moving things around.
Another one for the list!
Alex.
One thing i noticed using straight lines to cut an object that has depth it will cut without issue. Basically all sides stay intact but once you fillet the point section then when cutting the edges then the edge is gone maybe to complicated to hold the edge any thought thanks
Hi 3DFanatic,
> any thought thanks
Can you please post the 3DM model file with the object in it that you're having this problem with? It's hard to figure out what might be going on by just a text description like that, I'd need to be able to take a look at your object.
Good evening Michael,
I tried to emulate the same issue but all the test I did created the same open edge. Maybe you can give me some recommendations on how to reduce this issue from happing. I know to close the edge on the hard edge is very simple what becomes more complicated is the curved sections. I kept the lines and main objects that I swept before doing the second action which is what is causing the removal of the edge.
I was able to keep the edge when I extruded the line shape and then Boolean it. However once that is done the edge does not like to be fillet again causes all kind of artifacting.
Again always thanks for your assistance you make this program what it is, thanks
testing object.3dm
Hi 3Dfanatic,
What is the second action that you're referring to here, is it using Trim ? If so then when you're cutting a solid it is easier to use boolean difference instead of Trim. Trim operates only on surfaces, while the booleans work on solid volumes and are able to make a solid result automatically joining in the pieces of the extruded cutting curve. You can get the same result with Trim but it's more work because you'd need to extrude the curve into a surface and then trim that surface and join the results together. Booleans basically do all that work for you.
So for your case here with your solid you made from your sweep, select the solid and run Construct > Boolean > Difference, and then select your curve as the cutting object:
That will divide it into 2 solid pieces:
Delete the pieces you don't want and you'll be left with a full solid and won't have to worry about closing up holes as you would if you work only at the surface level with Trim:
One thing to note is that although it works ok for your case here, it's generally not good to have your cutting curve overlap right over top of other areas of the model like in this region here:
That can tend to complicate booleans because it's going to extrude out a cutting surface from that curve and the extrusion is going to be skimming right along the same surface area of your main shape and it's more difficult to get a clean intersection curve from stuff like that. In order to do booleans, a well formed closed intersection loop of curves have to be generated to divide the object up into different clean pieces. If the intersection curves are complex and criss-cross over each other that might not happen.
So instead if possible it's better to have a cutting curve like this where it shoots out a ways instead of having spots that hug right along the same shape:
Then for filleting, the problem there is your shape is very thin and so there isn't much room to fit fillets in, about the maximum size that will fit is around 0.01 units, if you try to use a radius much larger than that it would cause the fillets to collide into each other and cause the type of artifacting that you're describing.
So use a fillet radius of 0.01 or smaller for your particular case here, here's an example of what it looks like with 0.01 :
Hope that helps!
Thanks Michael!
That info helped, after all that do you have plans to give more control on skinnier objects so the fillet can be reduced past the .01 setting? Thanks for all your support
Hi 3DFanatic, you're welcome!
You can do that currently, for your particular case here 0.01 is about the maximum size that will fit, but you can go smaller than that if you want. For example here it is with 0.001 units:
With skinny objects if you get weird results try using smaller and smaller values, don't stop at say 0.1 units, keep going smaller and smaller to get a good idea of what's going to be possible to actually fit there.
With your shape here, a fillet of radius 0.05 takes up this much room just for one side:
It can be a good idea for objects with very small sized features like this to be modeled at a larger scale, like say build this object at 10 times larger than what you've got right now so that you're not working with too tiny values.
Thank you great advice i will increase the whole thing
Not sure if this has been mentioned already but here are two suggestions:
Extend surfaces X amount (like in Catia)
Remove chamfer/fillet by selecting and adjacent surface automatically extend (like in Powershape)
Hello,
Extrapolation of curves and surfaces would be a great addition to MoI. Scale that model up x10 and you can fillet the edges at .15 to get a complete round on the edges.
Hi Michael.
Have a nice day.
What do you say ? We can except a "hot" October :) ?
V4 is coming ?
Bye!
Hi Michael ...
Yes, I am on pins and needles. You have said 'soon' awhile ago. I'm confused about the definition of that word, :-).
cheers,
eric
Hi Marco & eric - it's getting awfully close! I've got a good path forward for the viewport display, I've been able to modify the rendering library so it matches up with what I need to do and I've got curves and surfaces drawing on screen now.
The main areas left are shaders, background images and text labels, hit testing, and more exploration of a fast path for high memory video cards. I've been thinking that I might release an early version before all that stuff is completely done.
Here's what it looks like at the moment (model by PaQ):
Ok Michael!
We're on the right track!
It seems to be a good starting point.
If you create some shader to apply to the base rendering it could become interesting.
I mean, ambient occlusion and some shader with environement illumination/reflection.
I stay tuned.
Hi Marco, well the first priority is for shaders that make curve and surface drawing look the same as V3.
For ambient occlusion that's something that I'd like to look at later on, but probably initially in a simple "offline" renderer. That's not something I'm targeting for the first V4 beta release though.
OK. No Problem.
For me the most important things of the new display engines should be these :
1) Improved antialiasing (both for curve/edges and surfaces)
2) No "display glitches"
3) Speed. Moi must take advantage of the modern GPU, if it is installed on the machine where Moi is executed.
I hope these things will be done within the V4 beta period.
Have a nice day.
208-227
228-247
248-267
268-287
288-307
308-327
328-347
568-574
