Full Version: Majik Tutorial: Cast Iron Skillet
Show messages:  1-5  6-25  26-33
17 May 2014   [#6]
Thank you Mike to show your way to use new variable-fillet tool (i didn't download newest MOI's version yet..)
Good virtual images too,it's hard to render that kind of material..
M
17 May 2014   [#7]
French translation next week, i have some other things on fire! :)
http://moiscript.weebly.com/poecircle-en-fonte.html
17 May 2014   [#8] In reply to [#2]
Superb tutorial Mike, you might have been missing a year, but you are still the Fillet master including the variable kind :)
Martin Spencer-Ford
17 May 2014   [#9]
Good tutorial, but it is a pitty, that it is not in metric measures.
17 May 2014   [#10] In reply to [#9]
Thanks all! :-)
I'm surprised I'm not seeing a more robust use of the new Fillets. :-o
Merci Pilou!
Aucune inquiétude... prenez votre temps. Aucune ruée.
Rudi, I had actually considered that along the way, and I might update some of the pics...
I had to back-track a lot, and I felt that there wasn't the likelihood that anyone following the tutorial would get the same exact result with the same numbers.
I may post the metric version of the chart.
20 May 2014   [#11] In reply to [#2]
Amazing as always. Nice to see a new tut from your hand. Thanks.
Peace,
Rich_Art. ;-)
20 May 2014   [#12]
French Translation Done!
I will just add tommorow some legends under the images for customise a little this superb tutorial!
20 May 2014   [#13]
Merci Beaucoup Pilou!!! =-D
It looks great!
I'll work on the web site links soon.
20 May 2014   [#14]
Here is my "Hand" rendering of the skillet. (I am so hungry now.)
This took about an hour using Taron's Verve fluid-dynamics painting program.
http://www.taron.de/forum/
Once Taron allows for input of images to trace from, Verve and Moi will be quite a pair!
20 May 2014   [#15] In reply to [#14]
Appetizing! :)
21 May 2014   [#16]
Great tutorial Mike.
21 May 2014   [#17]
French Translation definitely done! :)
21 May 2014   [#18]
The traduction dans le français looks great Pilou! :-)
I only regret not declaring metric measurements as well.
21 May 2014   [#19] In reply to [#18]
No problem, that is showing possibilities of differents units! :)
21 Jun 2014   [#20]
nice tutorial ;) nice that you use also verve ;)
thanks ... ;)
21 Jun 2014   [#21] In reply to [#20]
Thanks! :-)
14 Jul 2014   [#22]
Aw, heck yah!!
http://www.core77.com/blog/food/uk_rocket_scientist_designs_hyper-efficient_cookware_27302.asp#more
http://www.lakeland.co.uk/brands/flare
It's the Flare with Fin-X (not to be confused with Finex) Technology from a company called Lakeland.
The heat sink built into the bottom of these pans are designed to better transfer rising heat while better ducting the heat along the pan's surface.
Hopefully the inside surface is smooth, because I imagine it would be a nightmare to clean burnt food from inside of those grooves.
It's worth a model.
14 Jul 2014   [#23] In reply to [#22]
Mike - You're the master modeler of household appliances.
It's a proven fact that everything works better when you add fins. Everything.
Now, I'm going down to the junkyard, get out my welder, and make a set of new pans for my wife.
I love the smell of coffee and brake fluid in the morning!
Ed
18 Jul 2014   [#24]
Great tutorial, Mike, thanks a lot for sharing.
Now that I know more about MoI's tools and workflow than in my early months, I really have to go through all of the tutorials on your site again. Very educational.
18 Jul 2014   [#25]
You're welcome. :-) Enjoy!
