Full Version: Majik Tutorial: Cast Iron Skillet
Show messages:  1-17  18-33
21 May 2014   [#18]
The traduction dans le français looks great Pilou! :-)
I only regret not declaring metric measurements as well.
21 May 2014   [#19] In reply to [#18]
No problem, that is showing possibilities of differents units! :)
21 Jun 2014   [#20]
nice tutorial ;) nice that you use also verve ;)
thanks ... ;)
21 Jun 2014   [#21] In reply to [#20]
Thanks! :-)
14 Jul 2014   [#22]
Aw, heck yah!!
http://www.core77.com/blog/food/uk_rocket_scientist_designs_hyper-efficient_cookware_27302.asp#more
http://www.lakeland.co.uk/brands/flare
It's the Flare with Fin-X (not to be confused with Finex) Technology from a company called Lakeland.
The heat sink built into the bottom of these pans are designed to better transfer rising heat while better ducting the heat along the pan's surface.
Hopefully the inside surface is smooth, because I imagine it would be a nightmare to clean burnt food from inside of those grooves.
It's worth a model.
14 Jul 2014   [#23] In reply to [#22]
Mike - You're the master modeler of household appliances.
It's a proven fact that everything works better when you add fins. Everything.
Now, I'm going down to the junkyard, get out my welder, and make a set of new pans for my wife.
I love the smell of coffee and brake fluid in the morning!
Ed
18 Jul 2014   [#24]
Great tutorial, Mike, thanks a lot for sharing.
Now that I know more about MoI's tools and workflow than in my early months, I really have to go through all of the tutorials on your site again. Very educational.
18 Jul 2014   [#25]
You're welcome. :-) Enjoy!
22 Jul 2014   [#26]
Mike - mighty!
Which UI settings are you using? Enjoying that blue...
Cheers,
- Rich
22 Jul 2014   [#27] In reply to [#26]
You know, Rich...I didn't pay much attention to that before, but it is a great look.
Do tell, Mike! :-)
Ron
23 Jul 2014   [#28]
Thanks! ;-)
Your UI colors can be set in the .ini file.
Here are some examples listed under [view]: (Also within the View and Grid panels in the Options)
BackgroundColor=68,89,96
LockedObjectsColor=150,171,175
SurfaceColorMode=ByStyle
SurfaceFixedColor=192,192,192
EdgeColorMode=Darkened
EdgeFixedColor=187,187,187
EdgeLightenFactor=0.0
EdgeDarkenFactor=0.32
CurveColorMode=ByStyle
CurveFixedColor=0,0,0
LineUnselectedColor=0,0,0
LineSelectedColor=0,255,250
SurfaceUnselectedColor=255,245,245
SurfaceUnselectedTransitionColor=208,255,255
SurfaceSelectedTransitionColor=128,255,250
SurfaceSelectedColor=0,239,235
You can also tweak the aspects of each grid element.
My wife had this cool plastic cutting pad for crafts. It had a grid and a dark color scheme which I went for.
Since Moi's default objects are neutral-to-light shades, a darker background shows them up better.
As for the selected lines, Yellow has always been my least favorite color (yuk!) - so it had to go. ;-)
23 Jul 2014   [#29] In reply to [#28]
You are a gentleman, Mike. Thank you.
And your tutorials have been invaluable. You always make them interesting and fun.
Bets,
Ron
24 Jul 2014   [#30]
Cheers!
- Rich
Message 6706.31 was deleted
21 Feb 2019   [#32]
Mike's Tutorials should be stickied somewhere. They are so well written and eye opening! So here is a necro of an old thread out of respect :)
21 Feb 2019   [#33]
you may check the resources section:
http://moi3d.com/resources
There you will find a link to his site and his tutorials.
