25-44
45-64
65-84
85-104
105-124
125-144
145-164
465-483
How is a reasonable number of polys of an import obj file?
Try with these 2 ones separated from ZBrush with no result ;)
_importObj works fine
_subdiv_beta open for gear but...
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/pm3d_dog_1.obj quadrangles 8 000
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/pm3d_gear3d.obj triangles 3 300
And have you project for that or not ?
And this one ?
No caps in the result ! Does this normal ?
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/nocaps.3dm
French Version ;)
http://moiscript.weebly.com/subdivision.html
Frenchy,
""""""""""""""And this one ?
No caps in the result ! Does this normal ?""""""""""""""
You can trim the top and bottom faces of this type of object:
The other one looks like something is greater than 5? Maybe look to have at the most a quad case....
Hey Frenchy,
Here's a trick for you. You can subdivide up your ngons to allow them to work....
Max,
I love that the objects points remain editable!
If you can figure out how to keep the original faces and smoothing attached, this will be a mind blower... Replacing hexagon for me.... essentially, "box modeling" in MoI..... :o
Hi Pilou
100-200
I think this script will be more useful for subdivision modelling (like Siemens NX).
>>And have you project for that or not ? (Error: N>5)
As I said above, this script supports 3- 4- and 5-sided polygons only.
>>No caps in the result ! Does this normal?
Yes, it's normal. Pentagons isn't supported in fast mode.
Cool
Thx for the infos and tips and tricks!
This is great! Thanks Max!
Fantastic! You da man, Max, many thanks!
Sweet baby jesus this is powerful stuff. Max, I can't begin to tell you how thankful I am that you've implemented this and shared with the community.
While I only started a year or so ago with MOI as a step from STEP to FBX conversion, MOI has become such an invaluable tool that I've more or less gone from Maya polygon modelling to MOI parametric modelling* after nearly 15 years of using Maya. This addition feels like the last missing link between the two. Subdivision sketching can now be brought into MOI for finalizing.
Thank you, thank you, and thank you again.
/Rico Holmes.
*Yes, MOI's THAT good.
Same here, Rico. 14 years of 3ds Max (1998-2012), then I moved to Blender 3D (which is still my preferred 3D all-rounder), and not long after that MoI entered my life and stole my heart. ㋡
The only thing I really missed in MoI was the powerful branching of polygon subdivision modeling, but Max built an interesting bridge to that now.
Don't forget ExplodeMove after subdivide for cool possibilities!
Pilou, it looks great :)
P.S. Small update (Unsupported polygons stays selected)
Cool! ;)
Cool stuff Max!
Wow!
Thank You very much!!!
Finally found the time to try this cool script.
It looks great. Thanks a lot, Max! I especially love the minimal number of control points.
A question:
When using the max number of subdivs, you still see seams along the surface edges. Will those be gone in the Quality mode? Would be great if the surfaces would have seamless continuity.
All the best,
Metin
Hi Metin,
Thank you. This was one of the main tasks.
I'm working on it. Fast mode will be used for interactive tuning only.
Yes. At least I hope so :)
Here is the Tetrus stp, from an old topic, for testing purposes, if useful.
Not quite as pretty as the old "t-splines" version.
(I bought ViaCad, at the half price special, and used it to convert the stl to stp.
Thanks to those responsible for the tips.)
25-44
45-64
65-84
85-104
105-124
125-144
145-164
465-483
