411-430
431-450
451-470
471-483
Hi gara, MoI does not really have any tangency or curvature analysis tools currently, it's not a focus area for MoI.
But if you turn on metallic lighting and set some specular highlights on under Options > View > "Lighting options", you can look at the reflective highlights to see any major breaks.
Ok, thank you Michael!
The CCC script shows some curvature lines and radii, for curves.
Thanks bemfarmer, but this plugin does not work with the subdivision surface
CCC will work for curves obtained from a surface.
The curve can be an isocurve from a surface, or a curve copied from an edge.
Hi Brian, one thing to be careful about is a curve on a surface can have very different curvature properties than the surface itself.
Like for example, here's a planar surface that has curvy isoparms and edges:
I just successfully converted a retopologized ZBrush mesh to a solid thanks to ImportObj and Subdiv. Brilliant work, Max, many thanks!
Any chance of continued Subdiv development, like triangle subdivision optimization? It would be fantastic if you could make a smoothly subdivided solid from a triangulated, decimated mesh, like the output of Zbrush Decimation Master or Blender's Decimate modifier.
Thanks again,
P.S.: A tip: if your mesh is fully symmetrical, import and subdivide half the mesh into MoI, then mirror and join to a solid. It will save quite some calculation time, and enable you to import larger meshes with more polygons.
Message 6674.479 was deleted
Not essential but...
does it possible to have "Snap" when move segment during the SSplit ?
Hi I cannot get this script to run for the life of me I'm on windows 10 is there something I missing on the install? Goes into commands right for the SubDivbeta9?
Hi Dave, there are some instructions on how to install plug-ins here:
http://moi3d.com/faq#Q:_How_do_I_install_a_plug-in_script.3F
Some things to look out for - make sure you have unzipped it, you need to copy the contents of the .zip file into the commands folder, not the .zip file itself.
Then to trigger it set up a shortcut key with _Subdiv_beta9 as the command name.
don't forget the first "_" at the beginning of the name! ;)
you can have any upper or lower letters but not space in the name!
_subdiv_Beta9
_subdiv_beta9
_SUBDIV_beTa9
will work :)
411-430
431-450
451-470
471-483
