392-411
412-431
432-451
452-471
472-483
I was searching the forum here but didn't saw someone mentioned something regarding ImportObj script.
It seems like, if you have your objects in your other 3D app not perfectly world centered but instead somewhere in the scene - the ImportObj seems to completely ignore
object position/scale when imported in Moi3D, it will just import it in the center of the Moi3D scene. When you export back from Moi3D to other 3D app the object will not anymore be in the original position but instead centered in the middle of the scene.
What i usually do is when i model something in Maya and i see something would be just easier/faster/better to make in Moi3D, i will block it out and export as Obj then using ImportObj script import in Moi3D. At this point the object will not be anymore in original position/scale/rotation so when i am done working in Moi3D and export back to Maya i have to position/scale/rotate the object back in the original place again.
Is there a way currently for Moi3D and other 3D app get along nicely when import/export your object and for object to remember position/scale/rotation instead of, when you import obj, Moi3D to auto center it?
Hi keyi, there is an option in the importOBJ script to not normalize the object like it does by default.
There's some information here on the setting:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.201
To use it, modify your keyboard shortcut to give the parameter "exact", by adding it to the end of the shortcut separated by a space, so your shortcut should read like this:
_ImportObj exact
Also make sure you're running the latest one which you can find on Max's file archive here:
http://moi.maxsm.net/media/files/
Thanks you so much for this, Michael!! This is now extremely helpful! Thanks!
Actually super cool to have both options since sometimes i want to have object in the middle when importing in Moi3D but most of the time i really need to be
at original position. Nice.
Once again, thank you! ;)
the panel disappears or shows message "unsuppotred polygon type"
Hi glmr, please post the 3DM model file that you are trying to smooth when you see the error.
My guess though is that you have some faces in your object with 5 or more boundary edges on them. The converter will not work on that type of geometry, I think it requires all faces to have either 3 or 4 sides (triangles or quads).
this one. it is not an inported model, but just an extrusion from .ai file
Hi glmr, well I can see right away that you've got a top face on your extrusion which has 24 holes in it, which right there is not suitable for subdivision smoothing.
In order to do sub-d smoothing, your object needs to be made up only of 3 or 4 sided faces with no inner holes in any of them at all. So instead of one single face on the top with trimmed holes in it, the top part of an object like that needs to be tiled and made up of a bunch of smaller 4 sided faces that sort of flow around the holes.
Also you'd typically have an angular cage-like object as the base object to be subdivided, with all edges just being line segments, not starting out with curvy outlines like you've got there.
Sub-d modeling is a really different approach from a drawing based one like you're showing there.
Hello,
try to export the file to .obj-format to get triangles and quads. Then reimport the result with the obj-importer written by Max Smirnov. After that - run the script:-)
Have a nice day
Karsten
Hi Max,
can you help in install your subdivid beta9.
I have copied all the files (new importobj also) in the commands folder, but nothing happened.
Thank you for your help and incredible work in the created of subdivide surfacece.
Hi gara,
Did you install a shortcut key in MoI Options icon?
For example: Select Options / Shortcut keys,
and add a new entry of your choice, such as Alt+F in first column, then _Subdiv_beta9 in the next column.
or for example, Alt+/ _Subdiv_beta9
The prefix _ must match the prefix of the _Subdiv_beta9.htm and .js files. _ is not required, but its presence or absence must match.
Then close and open MoI again, load a solid polygon, such as Box, select it, and type in the shortcut key combo,
for example hold down the Alt key and type F.
(I now use Max's custom ui for Ext.scripts, instead of shortcut keys, and also use _ prefix for the non-basic MoI scripts)
Either method, or both methods may be used.
Thanks Brian,
now it works!
I had miss the step to close and open again MOI
I have imported a simple object like a cube, and the obj importer works, but as I apply the subdivision and change the value with the slider appear an error, and if I click done the object disappear.
Hi gara, the sub-d plug-in requires the object's faces to be quads or triangles, meaning all faces should have 3 or 4 boundary edges on them.
If you have something like a 5-sided pentagonal face in your object for example, that object will not be usable by the plugin and you'll get an error and behavior like you describe.
My guess is that's what you're running into, if you're not sure then please post the 3DM model file of your object so I can take a look at your particular case.
You would need to edit the model to be made up of quad faces before you can subdivide it, you can do this by drawing in some lines and using Edit > Trim to cut things into quads, or you also might try exporting out from MoI as an .obj file using the "Output: Quads & Triangles" option (not n-gons) and then importing that back in again.
I have use a simple cube for test the plugin, so it has four edge.
I have try also a cube created in moi, but the result is the same
Hi gara, over here I'm not able to reproduce any problem using a cube drawn in MoI.
What error message are you seeing?
I don't know if I attach the image in the right way, but the error is this
http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=140a23dbbe6dcd26987b7844d598d45e&filename=Immagine.jpg
Message 6674.468 was deleted
Hi gara, are you possibly running an older version of the script? Try getting the latest one named Subdiv_beta9.zip from here:
http://moi.maxsm.net/media/files/ .
Also what version of MoI are you running it with?
With this new version works perfectly.
There is a way to check the tangency and curvature?
Hi gara, MoI does not really have any tangency or curvature analysis tools currently, it's not a focus area for MoI.
But if you turn on metallic lighting and set some specular highlights on under Options > View > "Lighting options", you can look at the reflective highlights to see any major breaks.
392-411
412-431
432-451
452-471
472-483
