336-355
356-375
376-395
396-415
416-435
436-455
456-475
476-483
Somptuous!
Can't wait! :-)
Thickness possible or problematic for the last example?
Beta8
Added: open surfaces support
This version can be unstable. I need to optimize it, fix a lot of bugs, surface issues e.t.c.
Updated version will be soon.
Frenchy Pilou
The shell command can't process this shape.
Very funny scene! :)
And bravo for the task even some little glitches are maybe persisting!
French version ;)
http://moiscript.weebly.com/subdivision.html
GREAT and COOL-TOOL
Thanks a lot Max!
This is awesome, results are very cool, even stability seems pretty good.
I know this is lot of work in your free time, but do you plan something like Creasing edges?
Creased edges would be !amaze!
- Rich
And UnCrease or UnSubdiv also ?
Message 6674.406 was deleted
Message 6674.407 was deleted
Message 6674.408 was deleted
Hi Vojtěch,
Here is my subdiv script development plan:
- rewrite importMesh function (again)
- increase surface quality when smoothness setting <40
- improvements of open surfaces processing
v1.0 release (11.2015)
- increase overall performance of the script, rewrite couple of functions
v1.1 release (01.2016)
- per-edge crease settings
- surfaces stitching
v2.0 release (1h 2016)
- full support of triangle surfaces
- on-the-fly shape manipulation
v3.0 release (???)
Max,
FWIW, I think you should charge $ for this. It's very worthwhile. A similar type plugin, Artisan, for SketchUp is commercial. I know the guy who wrote it. Like you he had given lots to the community. By charging for one plugin, it was a way for those in the community to help support his continued efforts. And, as we all know, a 'contribute PayPal' button doesn't do very much these days.
Thanks for your tireless contributions! Really good stuff. :-)
Yes, an I could charge for tutorials! ;-)
But yes Max, very good job on such a valuable script, and thanks for the hours of effort - I for one will put it to use.
Will looking forward :).
And as wrote Chipp, contribution from users is something you should consider to help you with development.
Thanks for your work
I agree, this is definitely a development path worth investing in. Actually, I would prefer it if Max and Michael would get together and develop this into a fully integrated tool inside MoI. Especially in order to make the final 'on-the-fly shape manipulation' really come together.
I'm not sure such a brilliant synergy would ever happen though. MoI currently has a different toolset and philosophy, and I'm afraid it's outside of Michael's scope. At least for now.
Keep up the good work, Max!
Thank you, guys!
I found program block which allows to load selected objects separately. I used it in beta3, but I turned it off in beta4. Don't ask me why :) I just forgot about it.
Today I turned it on and I was shocked. Look how it works with open surfaces :)
Also I improved open surface engine. Now it processes vertices with more than two naked edges correctly (right one).
Wow! It looks really good!
P.S. Need to sleep. I'll post the new version tomorrow.
336-355
356-375
376-395
396-415
416-435
436-455
456-475
476-483
