327-346
347-366
367-386
387-406
407-426
427-446
447-466
467-483
Hey Max,
Do you think it might be possible to have an option to crease open edges ?
In practice it should even be the 'default' behavior, but I'm probably biased by Modo default settings.
BWAAA!!! SOOOO AWESOME Max! :-) ..oh, the evil plans are a conjurin'
I think PaQ's suggestion would make a lot of sense as a 'default'. Having an option to crease other (non-outer) edges would be the icing on the cake, if possible ;-)
Hi guys!
archetype
>>Can't wait to try those open surfaces!
Next weekend, I hope. Maybe earlier, maybe later :)
It's possible, I have it in the plans.
PaQ
Yes. I've wrote this script block yesterday.
It's looking great Max!
Wonderful, thanks Max !
That amazing Max!
Woah! Sweet!! Need to create a tutorial on *that* version!
Thank you :)
The work is going on successfully.
I need from two to five days to finish it. In fact I can do it during one evening, but I'm busy at work (as always) :)
Somptuous!
Can't wait! :-)
Thickness possible or problematic for the last example?
Beta8
Added: open surfaces support
This version can be unstable. I need to optimize it, fix a lot of bugs, surface issues e.t.c.
Updated version will be soon.
Frenchy Pilou
The shell command can't process this shape.
Very funny scene! :)
And bravo for the task even some little glitches are maybe persisting!
French version ;)
http://moiscript.weebly.com/subdivision.html
GREAT and COOL-TOOL
Thanks a lot Max!
This is awesome, results are very cool, even stability seems pretty good.
I know this is lot of work in your free time, but do you plan something like Creasing edges?
Creased edges would be !amaze!
- Rich
And UnCrease or UnSubdiv also ?
Message 6674.406 was deleted
327-346
347-366
367-386
387-406
407-426
427-446
447-466
467-483
