300-319
320-339
340-359
360-379
380-399
400-419
420-439
480-483
Good news, guys :)
It seems I've found a way to avoid MoI JavaScript API limitations which stops me.
Beta7 is coming. Or maybe v1.0 ;)
What a teasing and suspense!
API = Application Programming Interface
Right on Max!
Donate available on
http://moi.maxsm.net/
Tease indeed! :-/ Can't wait!
First tests. Yes! It works!
All wishes of success!
Ta-daa!
beta7
Flash Gordon! :)
Seems works like a charm!
(Trick for volumes with difficulties like here : export as OBJ with triangles
then _importObj (BY Max ;)
and voilĂ !
(That I love in this one is that I have nothing to translate! :) (for the moment)
Ops. bug found.
Pilou, download script again.
No problem! I had not time to find it! :D
So the French one! ;)
http://moiscript.weebly.com/subdivision.html
Finally, I implemented a new method for extraordinary faces. In fact, I don't like this method.. I would like to have ability to create surfaces with different control point weights using Javascript interface, but now it is not possible. Michael, could you make it in the next version of MoI? (it will not take too much time, because the engine perfectly supports them.)
But yesterday I found another way. :) I can generate a temporary STEP-file with surfaces descriptions,exactly as I need, and then import it back.
So, I don't need to split an extraordinary faces to parts anymore. :)
Other notes:
High quality switch has been removed. Now preview is always generated in the fast mode, and result - in quality mode.
Also I have removed "Show points" switch. Just double click on title to make points visible.
I still have rare problems with LoadMesh function. I'll check it later.
The script doesn't support opened surfaces and extraordinary triangles (excluding a polar triangles)
My volume above has not extraordinary faces ? (i must subdivise in triangles)
Or your next version will resolve this ?
I hope that open surfaces and extraordinary polys are a possibility someday... it would be neat to create organic shapes ending in clean and straight openings.
Great work Max! I'll play with this update soon.
Cool stuff Max, Thanks!
I ran it two times at S=50.
Thanks again Max!
Here's a sample to look at something I saw. You may chalk it up to "don't use it that way", or it may help you refine it for the future.
In the sample, if you manually enter a value a little larger, you can preview a kindof "harder edge" output (It starts to suck the walls in a little), but the "complete output" morphs from what is shown at the preview stage...
Steps. Try enter a value of 130,,, Note the preview looks fairly neat. Press done and look at result... (A value of 120 seems to give a result like the preview of 130, etc)
Anyway. Nice job again........
subdiv7_sample.zip
I spent a lot of time online looking at comma usage in javascript.
Is there a purpose of the comma after the curly braces: },
I'm guessing that such commas are ignored, and there to make the end of function statements clearer ?
Hi Max, great work!
Yes, I'd definitely like to add more direct access to all the various parts of curve and surface structure (control points, weights, knot vector, degree, etc...) to scripts in v4.
Frenchy Pilou
Yes, there are extraordinary faces in your model.
At this moment the script supports extraordinary quads only, not triangles.
bemfarmer
The purpose of a comma separator is to delimit members in a list.
For example:
var obj = {
a: 22,
b: 33,
c: function() {return this.a+this.b},
d: function() {return this.a*this.b},
e: function() {return this.a/this.b}
Mike K4ICY
I'll try to make it in the nearest future. 1-2 months.
BurrMan
I remember about this. It's old bug of hq mode. I just had no time to fix it, but I hope I'll do it soon.
So, don't use it that way :) At least now. ;)
Michael Gibson
It will be great! Thank you.
300-319
320-339
340-359
360-379
380-399
400-419
420-439
480-483
