115-134
135-154
155-174
175-194
195-214
215-234
235-254
475-483
Finema, I'm using MOI on a Mac.
Max, Wow great work!
Here is a mouse from a Cinema 4D example scene.
Oldman works perfectly with v6! :)
Thanks Max, for your work on this and other scripts!
I've been using it as a solid softener, works great!
Excellent!
PS Who is the author of Old Man ?
No idea Pilou, it's in the Modo content library.
Hi Max,
I've some trouble to convert the oldman in high quality with the B6.
The result (after a long computing time) is an half joined model.
I have join my .ini, maybe it's a scale/precision issue because of my settings ?
Here's a difficult model for you :)
Generate 524 errors, 474 recovered.
While some faces are very distorted, it's a watertight SDS model.
Hi Max,
You are great !!
It's OK now on my mac !!
I've tested with old man and it's perfect !
Thanks for us !
Hi PaQ,
the reason is perhaps the triangulation in ChildHead eyes and under the neck ?
Hi Max,
So the oldman hi quality is working fine if I switch my unit into from meters to centimeters in MoI.
Hi Finema,
I don't think so, I have also tested the same model with 1 extra subdivision model (so I have only quads), but the loader still dont like it.
PaQ,
I've modified ChildHead in C4D and close neck and eyes with quad and no triangles.
the subdivision in MoI is Ok now.
try it !
Hi Finema,
Thanks for taking some time into this, it helps me to resolve the issue.
The problem was not the topology, but the scale.
Your model coming from c4d was 3300% bigger.
So I scale up my preview model by 2000%, and now it loads just fine, even with the ugly spiky topology on the neck and the eyes.
No problem to subdivide it either in MoI !
Great !!
Glad you have resolve this problem.
In my case, if i import object non solid (non closed) or with triangulate polygons, the panel Subdidision disapear when i try to subdivise.
Curious !
The subdivision is OK when i test with your ChildHead-BIG.obj with triangle in neck and eyes....
Problem with this solid ! (from Sketchup) Disapears!
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/component_solid.skp
It's not directly the file, I import obj, Separate, Joint or Booelan Union, Move result beacause there are some alone lines (?)...
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/solid_from_skp.3dm
you have an ngon at the top and bottom. I think Max's script supports only tris and quads...
Cool! Yes you right! Excellent!
The process
SKetchup -->obj By Tig for free version of Sketchup
Import OBJ --> Moi by Max
Export OBJ from Moi (Quad + Triangle) :) By Michael
Import OBJ by Max
Subdiv! By Max
Bravo Max! And Michael for the Quad + Tri) :)
Hi Finema,
The panel disappear with non solid object here too, but no problems with triangles.
Ok
Thanks PaQ
Hello
I get an error if I import a object like known hypo or childhead. Can everyone tell me what is wrong?
Greetings from Bavarian
I think there is nothing wrong.
If all the errors are recovered, you should see the model imported, and ready to be subdivided (after a join surface command)
115-134
135-154
155-174
175-194
195-214
215-234
235-254
475-483
