86-105
106-125
126-145
146-165
166-185
186-205
206-225
466-483
Voluptuous!
As in the beta4, The Subdivision panel displays a split second and disappears.
have you tried to use beta 1 or 2?
sorry, no i haven't...
Where can i find it ?
can i install both version on my mac ? V2 and V3 ?
thanks
beta1
http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.82
beta2
http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.117
All versions of the script works with MoI V3 only.
i've tested with beta1 and beta2 and it's the same issue > the Subdivision panel disappear
in fact, the script run only with very simple object with low polygon (as cup in attachment)
but fail with more complex objects as hypo also in attachment
I wrote a new version of importObj script. Now it works much better with twisted polygons.
I've tested this model with different version of subdiv script. Beta 2 and 3 works good. In beta 4 I wrote new LoadMesh function. Seems it have problem with this mesh. I'll check it today evening.
always the same problem
panel subdivision split and disapear
I need more information.
MoI version, script version, 3dm model (not obj. I need exactly that model, which you are trying to subdivide.)
hypo.obj
MoI V3 (mac OS X)
_Subdiv_beta5, 4 ,2 or 1
Hypo.obj is opened surface. Subdiv script works with solids only.
ah ok !
Anyway thank you :)
With your help I found a bug in LoadMesh function :)
Upd: fixed
Well done Max!
Had a lot of fun with your importObj & Subdivision plugins.
Got this model from
http://opengameart.org/content/low-poly-base-meshes-male-female
Dinos
<< I found a bug in LoadMesh function :)
<< Upd: fixed
So where are the last releases of load OBJ and Polygonal convertor ?
http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.152
http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.145
Just made some work and got this results first is original polygonal model, second is from T-Spline third from Max last beta.
T-Spline makes even less surfaces than on original but Max's script much more. Looks like a lot of geometry optimization must be done.
As I wrote before, it's just a first part of the script. The second phase is stiching surfaces with ordinary edges.
btw, can you check number of control point in t-spline model.
Bonus script :) Subdiv Classic..
I wrote this script few months ago for testing purposes.
It produces subdivided polygonal surfaces using classical Catmull-Clark algorithm.
Hi Max,
Thanks a lot for the last update, I'm really impressed by the result (and I can be very anal with that kind of stuff :)) ... I have the impression that poles area are looking even better than what I've seen
with Npower sub-d Nurbs Oo ... the overall shape is much better now too !
EDIT
The last .obj loader works much better, but well ... it still fails with a lot of my testing models (some sds cage model topology can be very distorted, with extreme non-planar quads).
Wish I could start to promote your converter with some famous models from the modo library (like the hypo, or the old man that npower also use for their own promotional material).
Maybe Michael can give you some advice in that area ?, he should know lots of stuff about file format ... because the converter itself is really amazing !
I hope the surface optimization will not change anything about the overall continuity quality !
86-105
106-125
126-145
146-165
166-185
186-205
206-225
466-483
