72-91
92-111
112-131
132-151
152-171
172-191
192-211
472-483
Hi Max,
First thank you a lot for all the effort you did on this polygonal converter.
I have no idea of the complexity to write something like that, but I just want to point a general 'smoothing' problem with the method you are using. (and I'm not talking about surface continuity)
In the image :
A ) Max Sub-d : Low Quality
B ) Max Sub-d : High Quality
C ) Npower SubD-Nurbs.
My concern here is the wobble effect from the version B (Max Sub-d : High Quality).
This wobble effect is also visible on object silhouette. I know that I shouldn't compare your script to
a commercial 500$ product, but I'm wondering if it's something that might be improve in the future ?
In other words, while you manage to keep continuity between patches, it seems the side effect is an overall shape/silhouette deformation. It's something very obvious for polygonal surface subdivision people, used to see very smooth surface transition and ultra smooth overall silhouette. (catmull-clark)
Hi PaQ,
Thank you for this valuable information. I have some ideas how to improve quality.
Hi Max
any idea about my problem above ?
thanks.
I tried -ImportObj- with Lisa-head from C4D
Tried to join all surfaces but obviously take too much time
Obj file is 4 Mb,if saved in 3dm is 231 Mb
Hi Mauro,
That looks very dense - is it a several times subdivided result that is being exported? If so then you want to try exporting the base level control mesh rather than already subdivided geometry.
Ciao Michael
Lisa comes from C4D content browser,she's already subdivided
I joined small patches (much quicker) to few bigger patches and after all I joined all bigger patches into one solid. Much quicker than do it as one time consuming process (I used that for that bottle above). Maybe that helps.
Hi Mauro,
just in case you need to recover her... ;-)
http://www.mariussilaghi.com/products/subd-recovery
Finema
Sorry, I don't have a mac. But it's very strange, it should work.
Max,
I've tested all the example in this thread (and more) and none are running.
I've a 2 x 2,8 GHz Quad-Core Intel Xeon Mac Pro and 6 Go ram.
The Subdivision panel displays a split second and disappears.
No other Mac user had this problem ? It's curious...
Thanks...
Hi, yes I am a mac user as well and when running the script I see a window flashing up on the left upper corner and that is it.
Maybe this will be resolved soon but anyway your work is awesome !!
For me the subd script works well with MoI 2.52 (have not updated yet to 3.0) under OSX 10.8.5 with my old iMac.
Finema
Kroet
Check beta1 or beta2. Does it work?
Beta 5.
Fixed bug with high valence vertices (>16-20)
Some surface tuning. Not perfect, but smoother than beta4.
b4 - red, b5 - green
Upd: Fixed tolerance bug, which may cause errors while importing very small models. Reuploaded.
Voluptuous!
As in the beta4, The Subdivision panel displays a split second and disappears.
have you tried to use beta 1 or 2?
sorry, no i haven't...
Where can i find it ?
can i install both version on my mac ? V2 and V3 ?
thanks
beta1
http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.82
beta2
http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.117
All versions of the script works with MoI V3 only.
i've tested with beta1 and beta2 and it's the same issue > the Subdivision panel disappear
in fact, the script run only with very simple object with low polygon (as cup in attachment)
but fail with more complex objects as hypo also in attachment
72-91
92-111
112-131
132-151
152-171
172-191
192-211
472-483
