2 Mar 2014
To: ALL
Hi Nikola,
> By the way,when will be the new beta version of MOI3d V3 ready.
Maybe another week or so... ? I'm trying to jam in a few last features before wrapping up v3.
- MichaelReply
2 Mar 2014
To: ALL
Super NiceReply
2 Mar 2014
To: ALL
Wow! Great!
Does it support zero radius values?Reply
2 Mar 2014
To: ALL
Hi Max,
Sometimes... But it seems to be fairly problematic with that a lot of times. It seems to get in some difficulty with the "trim original faces" filleting stage. I'm going to do a bit of checking to see if I can possibly tune something about that up or also sometimes a small value like 0.001 instead of zero seems to work ok.
- MichaelReply
2 Mar 2014
To: ALL
Also I have a fix for filleting separate from this which will stop fillets from splitting into half lengthwise (like 2 long strips) which could happen sometimes previously.
- MichaelReply
2 Mar 2014
To: ALL
I was thinking more like the picture below however I could see it could get a bit messy GUI wise.
Can we have an indication of which set we are editing, like when picking a set the points show of that set?
Reply
2 Mar 2014
To: ALL
That's a nice surprise, Michael and a lovely implementation as usual.
Thanks very much!
Martin.Reply
2 Mar 2014
To: ALL
Now this is a nice addition, thanks Michael.
I love this, the most fast and quick and amazing fillet moi can do.
Reply
2 Mar 2014
To: ALL
Brilliant! My main feature wish for MoI is becoming reality :-)
Going to zero or very small values - that would solve a lot of problems here.
I guess that it also works for G1-G2-G3?
Would it theoretically be possible to define "stop points" if only part of an edge should be filleted?
Now my only major wish left is 64 Bit, but I'll happily wait for V4 for that ;-)
Cheers and thanks!
Tom
Reply
2 Mar 2014
To: ALL
Sweet, thanks for the update !
Reply
2 Mar 2014
To: ALL
Love-it!Reply
2 Mar 2014
To: ALL
A really clever solution, nice work!
I've been wishing for this for a long time.
Concerning points, will they be deletable?
Would id be a good idea to have some kind of visual indicator of the fillet points created?
I have know idea what amount work it would involve, but if it's an easy thing, having adjustable on-screen handles would be very cool.
MarcReply
2 Mar 2014
To: ALL
Hi Danny,
Ok, I see what you mean now... But I'm not quite so sure how awkward that would be to have a combined "set active set" menu and "edit any set" thing all trying to be packaged together like that.
I'll see if I can do something for this with the current system. This is another thing that would maybe be a bit awkward on an inline editor in the popup menu, I guess you would be talking then about switching things on screen just when keyboard focus went into each field?
- MichaelReply
2 Mar 2014
To: ALL
Hi Tommy,
Yes, it does work with those modes.
This is not normally done in filleting because trying to suddenly stop a regular fillet opens up a hole when there is an abrupt change from a curved fillet piece back to the regular portion of the object.
If you want to use variable radius to handle that hole issue by having the radius shrink to zero at that spot, then you could potentially try that by cutting the edge into multiple edges using the Edit > Trim command with the "Add trim points" option. Add a trim point at your "stop point" so it's split into different edges there. This does not seem to work very well though, it's not really something that the fillet engine is expecting to deal with.
- MichaelReply
2 Mar 2014
To: ALL
Great work, Michael! This will be a welcome addition for a LOT of the projects I work on!
Will this be in the next beta?Reply
2 Mar 2014
To: ALL
Hi Marc,
Sorry, no probably not. If you don't want a set of points you've already defined you would just need to cancel out the fillet and start a new one.
Yeah I'll see if I can put up the current set of points on screen.
Unfortunately that involves a whole lot of work and much more fundamental changes to how regular filleting would work. I'd like to have something like that in the future at some point but it's not what I'm trying to get done right now.
- MichaelReply
2 Mar 2014
To: ALL
Great - thanks Michael!
Cheers,
TomReply
2 Mar 2014
To: ALL
Hi Ron,
Yup, that's the plan!
- MichaelReply
2 Mar 2014
To: ALL
Great work Michael ...
ericReply
2 Mar 2014
To: ALL
How couples of points can we put along the fillet ?
(if I understand how all that work, that is not sure! :)Reply
9-28
29-40
Reply to All
