Full Version: New fillet stuff for variable radius
 2 Mar 2014
To: ALL
Interesting .... :)
Martin Spencer-Ford
Reply
 2 Mar 2014
To: ALL
Good goin' Michael !!
Smart as usual,mantaining same clear UI
A variable fillet tool just fitted to Moi..you think-it's done
or better:it's done before think ! :)
Reply
 2 Mar 2014
To: ALL
Well..well, you have been a busy boy Michael :) The new variable fillets option looks seamless to the whole feel, it's like it's always been there, great job!
Is it possible when hitting 'Current Set' for it to be persistent and each value to be editable with the preview updating with each change? would be nice for fine tuning, just a thought.
Reply
 2 Mar 2014
To: ALL
Appetizing!
It's a pity that don't yet existing in the Nurbs libraries you use!
So some works avoid ! :)
Reply
 2 Mar 2014
To: ALL
Great tool Michael.Easy and fast,as moi3d is in generally is.Keep up the good work.By the way,when will be the new beta version of MOI3d V3 ready.
- Nikola
Reply
 2 Mar 2014
To: ALL
Hi Danny,
> just a thought.
Yeah if I understand you correctly that is how it works - by changing the "current set" you can go back and adjust the radius value from a previous point set or the initial edge set (which is set #1).
Basically the current set controls which set the radius control is actually editing - when you change the current set it will stay on that set as you tweak the radius value and show you the preview, it will only change to a different set if you change the current set again or if you make a new one.
I think that's the same as what you're asking about - let me know if that's not quite right.
Reply
 2 Mar 2014
To: ALL
Hi Nikola,
Maybe another week or so... ? I'm trying to jam in a few last features before wrapping up v3.
Reply
 2 Mar 2014
To: ALL
Super Nice
Reply
 2 Mar 2014
To: ALL
Wow! Great!
Does it support zero radius values?
Reply
 2 Mar 2014
To: ALL
Hi Max,
Sometimes... But it seems to be fairly problematic with that a lot of times. It seems to get in some difficulty with the "trim original faces" filleting stage. I'm going to do a bit of checking to see if I can possibly tune something about that up or also sometimes a small value like 0.001 instead of zero seems to work ok.
Reply
 2 Mar 2014
To: ALL
Also I have a fix for filleting separate from this which will stop fillets from splitting into half lengthwise (like 2 long strips) which could happen sometimes previously.
Reply
 2 Mar 2014
To: ALL
I was thinking more like the picture below however I could see it could get a bit messy GUI wise.
Can we have an indication of which set we are editing, like when picking a set the points show of that set?
Reply
 2 Mar 2014
To: ALL
That's a nice surprise, Michael and a lovely implementation as usual.
Thanks very much!
Martin.
Reply
 2 Mar 2014
To: ALL
Now this is a nice addition, thanks Michael.
I love this, the most fast and quick and amazing fillet moi can do.
Reply
 2 Mar 2014
To: ALL
Brilliant! My main feature wish for MoI is becoming reality :-)
Going to zero or very small values - that would solve a lot of problems here.
I guess that it also works for G1-G2-G3?
Would it theoretically be possible to define "stop points" if only part of an edge should be filleted?
Now my only major wish left is 64 Bit, but I'll happily wait for V4 for that ;-)
Cheers and thanks!
Tom
Reply
 2 Mar 2014
To: ALL
Sweet, thanks for the update !
Reply
 2 Mar 2014
To: ALL
Love-it!
Reply
 2 Mar 2014
To: ALL
A really clever solution, nice work!
I've been wishing for this for a long time.
Concerning points, will they be deletable?
Would id be a good idea to have some kind of visual indicator of the fillet points created?
I have know idea what amount work it would involve, but if it's an easy thing, having adjustable on-screen handles would be very cool.
Marc
Reply
 2 Mar 2014
To: ALL
Hi Danny,
Ok, I see what you mean now... But I'm not quite so sure how awkward that would be to have a combined "set active set" menu and "edit any set" thing all trying to be packaged together like that.
I'll see if I can do something for this with the current system. This is another thing that would maybe be a bit awkward on an inline editor in the popup menu, I guess you would be talking then about switching things on screen just when keyboard focus went into each field?
Reply
 2 Mar 2014
To: ALL
Hi Tommy,
Yes, it does work with those modes.
This is not normally done in filleting because trying to suddenly stop a regular fillet opens up a hole when there is an abrupt change from a curved fillet piece back to the regular portion of the object.
If you want to use variable radius to handle that hole issue by having the radius shrink to zero at that spot, then you could potentially try that by cutting the edge into multiple edges using the Edit > Trim command with the "Add trim points" option. Add a trim point at your "stop point" so it's split into different edges there. This does not seem to work very well though, it's not really something that the fillet engine is expecting to deal with.
Reply
Show messages:  1-2  3-22  23-40
Reply to All
Back to thread list | Login
© 2018 Project Beehive Forum
