7-26
27-40
Great work Michael ...
eric
How couples of points can we put along the fillet ?
(if I understand how all that work, that is not sure! :)
You can put any number of points, the points go on the original edges. But usually you'll want to be fairly sparing with the number of points used because using too many too tightly packed together will make for a sort of "bunching" effect:
Thx! All is clear now!
Even your last example who can be a wishing form in some new designs! :)
BWAHHH!!!! =-D
A man journey's out of the village for a few days and a luau is thrown without him!
What a great surprise.
You are awesome, Michael!!!
Oh, I so can't wait to play with variable fillets.
So, question:
1) since points can't be deleted (if we flub), so I'm guessing you can re-position them?
2) will it work on fillets that branch off from intersections? What I mean is, will this work on all the complicated places fillets usually work?
3) The question asked earlier... but can you assign any type of rounding; G1-3 separately on each control set?
4) Okay, and one I thought about a long time ago... can the variability be as simply as filleting just one edge corner, where you can start at one radius and end at another.. looking kinda conical?
Okay, so keep up the great work! - thanks!
Hi Mike,
Nope, if you have put them in the wrong place then you'd just need to cancel the command and start a new one. Same thing as if you selected the wrong edges to fillet.
Well, it tries to do it in the same places, but it seems that they're a bit more finicky when it comes to intersections though.
No, currently the setting for whether doing round or G1-3 applies to all the fillets being done, there isn't currently any way to assign different rounding styles to different fillet sets. Maybe in the future I can add something in for multiple "edge sets" as well as "point sets" that might be a better fit for also assigning these per-edge properties.
You can do the "just one edge" thing, but it currently does an "ease-in/ease-out" type blending on it so it doesn't look quite conical, it looks like this:
I'm trying to see about maybe fitting in a "linear" option you could enable somewhere to get a conical shape, or also maybe if you're doing an edge with only 2 stations along it I should just do a linear blend in that case, I haven't quite figured that out yet.
Wow it looks really great
Awesome stuff Michael...
Peace,
Rich_Art. ;-)
What an awesome effect!
Thanks Michael.
So, maybe a "linear" option for each point (or point set)?
Also, will this also work for Chamfer?
Hi Mike,
Yeah maybe something like that, it has yet to be determined.
No, probably not for v3. This could happen in the future sometime though.
Woaw !
Really happy that it will be in version 3 and available soon.
Thanks Michael :-)
I am trying to use the variable radius feature, but I can't use large radii, I used the proportions of the instruction movie above, but it fails. what am I doing wrong?
filletttest.3dm
Hi wim, you didn't do anything wrong, it's just a bug in filleting where it's having a problem in the step where it tries to trim away the area of the main object to make a place to attach the fillet. When that happens the fillet surface will still be generated so you have something to work with and you can use Edit > Separate on your main object to break it into individual surfaces and then use Edit > Trim on each surrounding surface to cut it with the edge of the fillet to finish the model.
OK. it works till a certain extent, I am afraid.
I'll wait for the bug fix ;-)
cheers
wim
7-26
27-40
