458-477
478-497
498-517
518-522
Hi Colin.
If I remember correctly, this plugin is installed separately, then you need to delete its files.
I also have the file " 88 SubdivTools.js" but renaming it doesn't work, only deleting or moving it.
I don't see it in your screenshot.
Hi Colin,
> All of which makes me assume it must be part of the original V3 Command Bar install..?
No, those sub-d buttons are not part of the regular V3 UI.
But they may pre-date CustomUI and may have had instructions to insert them by modifying CommandBar.htm .
If you can post your CommandBar.htm I will see if that's where they are.
Thanks for clarifying that.
Here's that CommandBar.htm you're wanting.
HTH, Colin
CommandBar.htm
Hi Colin, yeah they were added in to there.
I've edited them out so if you replace your current CommandBar.htm with this attached version that should get rid of them.
CommandBar.htm
Thanks greatly for that, it's much appreciated.
Just tested & works a treat.
regards Colin
458-477
478-497
498-517
518-522
