370-389
390-409
410-429
430-449
450-469
470-489
490-509
510-522
Hi guys,
I have re-installed both (moi_v3_setup) and (moi_v4_beta_Jan-22-2020_setup)
Then extracted (CustomUI.1.03.win.mac) into MoI3 and extracted (CustomUI.2.0.beta2) into the Roaming\MoI directories.
I am able to get a list of SHORTCUTS in MOI3 but cannot get to the shortcuts in MoI4
When I had a look in the (...\AppData\Roaming\Moi\startup) There is a list of all the buttons that populate the bottom Bar.
But SHORTCUTS is not there.
I have had a search around on the Discussion Forum but could not find an answer
Hi Maysky, yes it looks like the CustomUI for v4 does not have a shortcuts button like the one for v3 did.
Ok, So what has to happen for a ShortCut-access-point to be created in the MOI4 customUI?
I guess this question is inappropriate. Sorry.
Hi Maysky,
First copy the HTML file for it from the v3 CustomUI which is at customui\mods\Shortcuts.menu.htm . Put that into the appdata\Moi\customui folder where there should be other .htm files like "Scripts.menu.htm" and "ObjLibrary.menu.htm".
Then inside the appdata\Moi\startup folder, make a copy of the "80 Scripts.js" file and name it "82 Shortcuts.js" . Edit the new file "82 Shortcuts.js" and change where it has:
var title = "Scripts";
to instead have
var title = "Shortcuts";
and also where it has:
var menu = "moi://appdata/customui/Scripts.menu.htm";
to instead have:
var menu = "moi://appdata/customui/Shortcuts.menu.htm";
Then you should have a Shortcuts button next to Scripts on the bottom toolbar that will work the same as it did in the V3 CustomUI. I think the way it is set up is it will show a menu of shortcut keys that have script code in them where there is a comment marked with a ! sign in it, like if you have a shortcut key set up like this:
script: /*!Invert selection*/ moi.geometryDatabase.invertSelection();
that will display as an "Invert selection" item on that Shortcuts menu.
Wow! thank you Michael
I will give this a go.
I thought I was being rude
Worked like a charm MoI 4 now has a Shortcuts menue :)
Thank you again.
The Syntax error is still occuring on manual selection. :(
Hi Maysky,
Update the Shortcuts.menu.htm file for v4 with the one from the other thread here to fix the error message that was happening with scripts containing any ' characters in them:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9891.5
The same fix for v3 should work for v4 as well.
Hi Moi’ers
Excuse me for being a noob with PC (use only Mac) V3
I have installed the custom UI but I dont see any icons in command bar?
I need the full extension script icon to be visible.
Which location shall it be extracted to, c:/users/username/programs/moi3d...... or /appdata/roaming/moi3d
I also have a question about how to write file location in PC.
When using ’exporttoseparatefiles’ script I wish the fbx files to be saved in a folder on desktop ”FBX”.
Is the path correct using
C:\\users\\username\\desktop\\FBX\\
* Michael for Nobel Prize *
Hi Stardust, for Moi version 3 on Windows you need to unzip the CustomUI.1.03.win.mac.zip file attached to the first message of this thread. There are 3 folders stored in the .zip file: objects, snapshots, and ui.
These need to be copied into the install folder at C:\Program Files (x86)\MoI 3.0
So copy the "objects" folder over so you then have C:\Program Files (x86)\MoI 3.0\objects
Do the same for the "snapshots" folder so you should then have C:\Program Files (x86)\MoI 3.0\snapshots
Then for UI it's slightly different because there is a ui folder already existing at C:\Program Files (x86)\MoI 3.0\ui . So you want to copy the contents of the .zip file ui folder into the existing ui folder. There will be one file (CommandBar.htm) that will be overwritten which you want to allow.
For v4 it's different - for v4 there is a different .zip file to use and it goes in appdata not the install folder.
Hey Gang:
I could not get this to work.
It shows a menu stub, but no content; in spite of the fact that my Moi.ini is chock-full of ShortCuts.
Have I made a mistake in my ".\startup\82 Shortcuts.js" file, attached?
I used the ".\customui\Shortcuts.menu.htm" file downloaded from
9891.5.
Many thanks to all of you !!!
Mindset
82 Shortcuts.js
Hi Mindset, if I remember right it only displays shortcuts that are marked in a certain way, I think with a ! character inside the script comment which is the /* */ part.
If you modify your shortcut keys so that it has it like: /*! */ do they then show up?
Thank you Michael.
You are a superstar.
Seems that the operative phrase is:
title = line.match(/\/\*\!(.+)\*\//);
So, I tried this on "MoI 4.0 beta Jan-22-2020":
script: /*! TOGGLE CURVES HIDE*/ var allcurves = moi.geometryDatabase.<<...etc.>>
... albeit to no avail.
So, hmm, I don't know what else to do. ???
Mindset
Hi Mindset, ok so the file "82 Shortcuts.js" should be in %appdata%\Moi\startup and Shortcuts.menu.htm should be in %appdata%\Moi\customui .
Is that what you have ? What happens when you push the button, is anything shown at all?
After much confusion, I finally got customUI shortcut icon to work, as per Michael's instructions for the shortcut .js and .htm files.
Pressing the button on the task bar shows 5 shortcuts, (so far, prior to doing any /*! */ edits).
(I used "83 Shortcuts", because 82 is being used with Snapshots.)
(With Moi V4 beta)
One of the 5 shortcuts showing had this format: script:/*!Select edges v1.2 */ var gd = moi.geometryDatabase; func.....
After adding a new shortcut key to MoI (V4), close and reopen MoI.
I could not locate the script: script:/*! +TOGGLE CURVES HIDE*/..., in order to test it.
I GENUINELY appreciate your time, attention ...and most especially your help.
When the button is clicked, it displays a stub, as shown:
However, as you suggest, once I moved "Shortcuts.menu.htm" from...
..\AppData\Roaming\Moi\ui\customui\
to
..\AppData\Roaming\Moi\customui\
it started working as expected !!!
Moi must be the greatest software in the world and a primary reason is how we, the user base, are treated and treat each other on this forum.
Thank you mightily !!!
In the upcoming release of V4 have you considered building the custom UI into the release maybe in the installation process can you choose classic UI or custom UI - I think with modern screens and extra pixels the custom UI install is very useful in having those tools ready to go and provide a comfortable working environment that is still simple but extremely powerful.
Just a random thought.
Alex.
Hi Alex, sorry no that's not something I've been planning. It doesn't really fit with the overall design of MoI which is focused on being streamlined and not showing a whole bunch of buttons at the top level all of the time.
But at some point I do want to make a mechanism for managing that area of the UI so you could promote some of your most frequently used commands there.
I haven't tried any sort of custom UI but I did like the idea of a "library" button.
That would seem to be in keeping with the idea of streamlining things.
Granted it doesn't save a lot of steps but it would be pretty nice just the same.
Frederick
It would be nice if snapshot had a popup menu associated with it, for the different modes.
Maybe an html file could do this?
Hi guys, a quick (and simple I guess) question: how can I install the Custom UI Beta 2 in MoI 4 (Beta Jan 22 2020)?
What I've done so far:
1) Downloaded MoI 4.0 Beta Jan-22-2020 from
http://moi.maxsm.net
2) Unzipped directory and copied into C:\Program Files\MoI 4.0 beta Jan-22-2020
3) Started MoI.exe
After that, I cannot see the custom bar. Is there something I'm missing here? I've been reading the forum, but I cannot find what's wrong. Should be something obvious.
Thanks for your help.
370-389
390-409
410-429
430-449
450-469
470-489
490-509
510-522
