285-304
305-324
325-344
345-364
365-384
385-404
405-424
505-522
Hi Tharso,
> Hi, Where can I find light options addon? I found one that didnt work with this plugin. Thx
Which version of CustomUI are you using - the one for MoI v3 or the one for MoI v4?
Just tried to apply CustomUI to new beta, but it doesn't worl correctly - scripts, object and lighting options folders are empty. Anyone has CustomUI setup which works for last beta?
Hi glmr,
The latest version of customUI works very well when installed properly in MoI4 beta.
Are you Mac or Windows?
I am on Windows. MoI 4.0 beta Oct-17-2018
UPD: I'm an idiot who doesn't read instructions. Now it works.
UPD2: can't find snapshot button even with correct installation
My camera icon is also missing in MoI4beta. It is present in MoI3.
Hi glmr,
re: UPD2: can't find snapshot button even with correct installation
Is there a file Snapshot.js located in your MoI appdata\startup folder?
My 82 Snapshot.js file was missing from MoiAppData\startup.
Downloaded max's v2 of customui from his website, to downloads folder, extracted, and copied
82 Snapshot to the MoiAppData\startup directory, and the camera (snapshot) is back.
A few other .js files are still missing, maybe messed up with MiniSidepane.js alterations???
Hi Brian, I wouldn't think that MiniSidepane.js alterations would be able to make files go missing... Is it possible you had an older version of it? The latest one from Max's file archive here:
http://moi.maxsm.net/media/files/ (look for CustomUI.2.0.beta2.zip) has it, maybe it was missing from previous versions.
Hi Michael, You are likely right. My initial install was for the first beta. It is nice to have link to current version. I keep links to such useful sites in Chrome bookmark bar. (I use snaggit13 quite a bit for window captures, rather than snapshot.)
Hi All,
I would like to install customUI to MoI 4 latest beta and have it portable but what I read so far I would have to extract the custom UI to appdata of user instead of MoI directory.
Is there any way to customize a MoI4 and have it portable?
Super benefit would be if I won't have to go through same complicated process of customization over again if newer version of MoI is released.
Thanks a lot.
Hi Mr. Yuri, if you create a folder named "appdata" inside of the MoI portable folder as a sibling to "commands", "ui", etc... then MoI will use that folder as its appdata location instead of the regular spot. So you can use that to make a portable set up of anything that is designed to be in appdata.
I'd recommend setting up whatever you can inside the appdata folder and then you would just need to copy that folder over into the new version.
What is the moi portable folder?
Just now trying to convert v3 to v4 Beta and now realize that customizations can be separated in the appdir folder instead of install folder but not sure if I need to make a folder in appdir and install ui, script, commands etc there instead?
Thanks!
Jason
Are people setting up portable MoI on a USB Flash Drive?
Max made an update to the custom UI that moved its i stall to the appdata folder, to stay vompatable with MoI's move to that folder... that is where all things are installed now, excepting MoI's root install dir stuff...
To get your "portable" MoI, you need to have all that appdata dir in your MoI root install location. Wotks just fine.
@bemfarmer
People do!!!! All my MoI installs have been setup this way. It's all on a usb stick. With me wherever i go!
Hi Brummett,
It's the folder where you have copied the MoI installation. It's for the case where you're using MoI as a "portable" program meaning that it is copied on to a USB drive and can be run directly from the USB drive on another computer.
MoI v4 will automatically create folders in appdata for commands and startup scripts. You can put your custom commands in there instead of inside the install folder, that way new installs will see them automatically and you won't have to copy those into a new install.
If you have made a scripts folder in your install you can also create a scripts sub-folder in the Moi appdata folder and put them there.
UI modifications would still need to be applied to the install, but if the UI modification is done by script code rather than static file changes, in v4 you can put the script file in the appdata startup folder so it will be run when MoI launches. Max's CustomUI extension for v4 has been redone to work this way for example.
Michael, that is very clever to set it in this way.
I mean if program detects "appdata" folder in MoI root it will putt settings from it.
And seems very easy to transfer all customizations to later versions.
Good job.
I also have one question.
How can we edit the icons we see in icon bar at the bottom of the program?
I have there 2 icons "Scripts".
One has stuff from custom UI + ones I copied to commands folder under appdata and other has also stuff from commands folder but it looks same as in my MoIv3.
I think I saw the post somewhere but probably putting wrong keywords into search.
Regards,
Juraj
Hi Mr. Yuri,
The standard ones on the bottom toolbar have PNG icon images in the \ui\icons subfolder inside the main installation folder.
For the ones from CustomUI, those icons are embedded inside the CustomUI script file using a method called base64 encoding which converts a binary file to a text representation.
So for the CustomUI scripts icon you'd need to find the script file for it, probably Scripts.js and then replace the embedded image data inside that file.
Some info on generating base64 encoded images here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.91
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.290
Thanks for the clarification. So to install the node editor. I would do it in the %AppData%\Moi\(folders shown in archive node editor.zip from Max) ?
Reason I ask is I can't get this to work. I have Custom UI v2 for beta installed and when I click on NodeEdit button, I just get a blank popup window with nothing?
285-304
305-324
325-344
345-364
365-384
385-404
405-424
505-522
