222-241
242-261
262-281
282-301
302-321
322-341
342-361
522
Windows or Mac?
Hi Neil, re: saving to objects library not working - it's probably a permissions issue. Please see if this helps:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8824.15
你好!
请问这个脚本如何安装?
我使用 moi3d v3版本的
按照您说的方式安装CustomUI v2.0 beta2,却无法使用,请问你可以提供详细教程吗?
谢谢!
how is possible to change snapshot's view? I'm trying different views, but every time get only right view snapshot
Hi glmr,
To set the focus on the desired view, first click on a shape in the view, then use snapshot.
Michel
thank you! it works now
@aivo (ANYOTO) 它不与版本Moi3d v3工作. 您必须安装Moi V4 Beta版本.
@Max Smirnov If you don't mind what file and value has to be changed to get a different thumbnail background of the asset icon other than default white? As I am using dark UI, my obj library looks quite odd now. I would like to have change it with your help.
Too bad I will now have to reprocess everything :D Maybe that could be an option if that's even possible.
Thanks a lot!
Replace the png Base64 image in 70 ObjLibrary.js, under startup folder, (Moi4 beta).
https://jsfiddle.net/casiano/xadvz/
As a test, I replaced the icon with the red bus with blue windows, by copying the base64 code, in Moi4 beta. :-)
(The gif code seemed to work ok as png...)
(EDIT Michael 4/13/2024 - removed broken link)
Hi Agonyii,
To change a thumbnail background color you need to open ObjLibrary.menu.htm and edit this line:
moi.view.viewportBackgroundColor = 0xFFFFFF;
Set any color you want.
@Max
I've also changed border value to '0' from (border: 2px solid;) to get rid of the border around preview.
.preview{ width:75px; height:75px; overflow:hidden; position:relative; border: 2px solid; border-color:#fff; }
I hope this could be valuable information for someone else as well.
Also just crossed my mind, maybe transparency support would the best solution if that's by any means possible?
Thanks so much Max! Much appreciated!
Hi agonyii, sorry currently there isn't any way to have transparency for the viewport background when doing a view snapshot.
I was afraid you would say that :D usually you bring the good news :D Appreciate it anyway!
Hi agonyii, I did happen to recently look into the possibility of making an option for that, but I found that it would require some major changes in the display engine for curve drawing. The way curve drawing works currently for the viewport display is based off of blending against an opaque background.
Message 6507.296 was deleted
> @Max hmm it seems, I still have an issue.
> I've changed '0xFFFFFF' to the '0x333333' as instructed.
> Even though #333333 is now set as thumb background color it still ads a prop with a white background. When I reopen Moi, my thumb background is properly displayed with #333333.
> Strange. Appreciate it if you have a clue what's causing that.
Ah never mind, solved it! Thumb was still white only because I was overwriting the preexisting asset. When you overwrite an asset, Moi is basically loading the old - cached icon until you reopen the app.
I'm leaving this here for the reference :D
I like this custom UI very much.
Any way, to get a "dark" version for this UI?
Or can I change this somehow by myself?
(but have absolutely no knowledges about scriting etc.)
regards
Mike
Hi Mike, do you have the rest of the UI set up to be dark and only the CustomUI pieces aren't?
If that's what you've got can you maybe post a screenshot?
So installed CustomUI.2.0.beta2 into MoI 4.0 beta May-12-2018 and my lighting options are no longer there. When I tap on the lighting Icon I get the message "Lighting Options add-on not found!" I'm also getting...
ReferenceError: Can't find variable: _Subdiv_beta9
line 1
1: >> _Subdiv_beta9
ReferenceError: Can't find variable: _sBridge
line 1
1: >> _sBridge
ReferenceError: Can't find variable: _sSplit
line 1
1: >> _sSplit
ReferenceError: Can't find variable: _sScale
line 1
1: >> _sScale
ReferenceError: Can't find variable: _ImportObj
line 1
1: >> _ImportObj
I'm sure I installed it correctly but I wondering what's going wrong with the update. I'm really concern about my lighting options.
Ogar
Hi Ogar, so those "can't find variable" errors come from MoI trying to execute that text as literal script code. But it will only do that if there was no command with that name found so maybe things are installed one directory too deep or something like that.
You should have .js and .htm files with those names in either the MoI appdata commands folder (%Appdata%\moi\commands) or the beta's built in commands folder (c:\Program Files\MoI 4.0 beta May-12-2018\commands) to avoid that error.
For lighting options I seem to remember that some modules of CustomUI are not enabled by default, you need to enable them by something like removing a leading character from the filename which CustomUI looks for and skips that module if its present.
222-241
242-261
262-281
282-301
302-321
322-341
342-361
522
