206-225
226-245
246-265
266-285
286-305
306-325
326-345
506-522
Hi hairykiwi,
at the moment MoI (and CustomUI) doesn't support an external script directory. To make ExtScripts work you need to remove ExtScripts.cfg.htm file.
Hi Max,
Many thanks for your reply - that's great to know, but also adds to my confusion.
Are you saying it *did* work (under v3?), but under v4 currently doesn't, or the feature never did work?
Either way, it would be great if you could clarify the instructions you wrote about this feature in your initial post, copied below - or consider adding to that first post a link to later posts detailing significant changes. I appreciate what I'm suggesting is a bit of a hassle, but I thought I'd read all the 260+ posts to ensure I was up to speed on the latest install details, and don't recall reading anything saying the feature wasn't active.
quote:
By default this addon checks only /commands directory, but you can create /customui/mods/ExtScripts.cfg.htm with notepad to add any directory you want.
Example:
MOI\commands
MOI\commands\myscripts
MOI\myscripts2
D:\dir1\dir2\myscripts3
Much respect for all you've done,
Hamish
CustomUI v2.0 beta2
This version works with MoI v4 beta Feb-09-2018 only!!! (and with all later versions of course)
CustomUI should be stored in AppData directory. CustomInit loader has been removed. Now CustomUI uses appdata/startup directory.
Installation (Win):
Remove all previous versions of CustomUI
Extract CustomUI.2.0.beta2.zip to C:\Users\<username>\AppData\Roaming\Moi\
Installation (Mac):
Extract CustomUI.2.0.beta2.zip to /Users/<username>/Library/Application Support/Moi/
After installation remove all unneeded .js scripts from startup directory
P.S. I have some problems with Screenshot addon. I'll add it later.
UPD: I wrote a simple javascript injector which works good with the new MoI's loader. Screenshot and CamSwitch mods has been added.
EDIT 2/13/2023 - (Michael Gibson) Download link here:
Hello Max!
Thank you very much for this update!!
I have only one problem, I don't have subdiv_beta_10 but only beta_09.
Where I can download it ?
Thanks a lot for support!
Hi Marco,
It's my fault. subdiv_beta_10 is not released yet :)
I uploaded a fixed version of CustomUI archive.
No problem Max!
Uploaded this new version and all works fine. Thanks :)
Ciao!
Hi there,
Sorry ... but I really would like to ask you if it wouldn't be possible to make a little video tutorial on how to install the CustomUI.
I work with MoI3d v.3 and got the CustomUI v.1.03 but I wasn't able to get the desirable result.
Thank you.
Hi jing,
What operating system are you using? Can you show a screenshot of where you've copied the files?
Max - your latest CustomUI + MoI v4 beta Feb-09-2018 is now even easier to install and maintain - THANK YOU :)
One reminder suggestion/tip for CustomUI newbies - instead of:
I still prefer Max's initial suggestion from his first post (edit by me in square brackets for latest Win location):
>Go to the [Win: %APPDATA%\Moi\startup ] directory and select modules which you want to use. To disable module, just put "-" symbol at the beginning of a filename (most of modules are already disabled).
- Hamish
I put a subdirectory in the Startup directory, to save a copy of the removed file(s). (Saved a copy of Max's sidepane mod, in case I want to use it in the future.)
Hi Max;
I Installed CustomUI per your instruction for MoI v4 beta Feb-09-2018, window version. I am getting error message when MOI starts. the *.js files in startup folder do not load.
Any idea what is the problem?
-sharif
Hi Sharif, the error looks like the CustomUI script code isn't able to access an element that it's expecting to find in the CommandBar.htm file.
Did you possibly copy an older version of CommandBar.htm into your current installation?
Hi Michael;
I have customized the commandbar.htm. It works with CustomUIBeta1, But it doesn't work with CustomUIBeta2. I have attached the commandbar.htm file that I am using.
Thanks;
-sharif
CommandBar.htm
Hi Sharif - your customized version is based off of an old version of CommandBar.htm . You'll need to reapply your customization on the newer CommandBar.htm that's included with the Feb-9-2018 release in order for the latest CustomUI to work properly. If you just copy over your older file you end up losing changes in the regular install.
Hi Michael;
I modified the new commandbar.htm and everything works now.
Thanks for help.
-sharif
great thank you! i have just purchased moi 3d V3 and am trying to install the (SMIRNOV) custom ui its adding everything like alignments and scripts ok, but i cant seem to save my objects to the object library. the option to put in name comes up i type a name but when i click the library the new item not there just the default 3 objects cube, sphere and plane surface ....i cant find what im doing wrong in any forum could you offer any advise?
best regards Neil
Windows or Mac?
Hi Neil, re: saving to objects library not working - it's probably a permissions issue. Please see if this helps:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8824.15
你好!
请问这个脚本如何安装?
我使用 moi3d v3版本的
按照您说的方式安装CustomUI v2.0 beta2,却无法使用,请问你可以提供详细教程吗?
谢谢!
how is possible to change snapshot's view? I'm trying different views, but every time get only right view snapshot
206-225
226-245
246-265
266-285
286-305
306-325
326-345
506-522
