160-179
180-199
200-219
220-239
240-259
260-279
280-299
520-522
>> I prefer to use shortcuts and Ext.scripts addon. It's much faster than typing.
Typing must be faster than searching sth. here:
http://moi3d.com/forum/lmessages.php?webtag=MOI&msg=6992.4
But I guess, I am going to try to add an input field to that menu and some jQuery that updates the table while I'm typing. Or so. I'll attach it somewhere here should I come up with something useful.
Hi Everyone,
Hope this helps any of those
Mac Users who want to create a CUSTOM folder (say a Dropbox folder) for their Object Library files. I do this so that I only need to keep one folder on Dropbox and all the library files automatically show up both at work and at home.
You'll need to find the file: ObjLibrary.cfg.htm in the
mods folder and edit it from:
Object Library;MOI\objects
to: (use the accurate path to your file. See
HERE for how to properly find the file path on MacOS.)
Object Library;/Users/chippwalters/Dropbox/Moi/ObjectsDONTMOVE
NOTE the slashes are going the opposite way!
Next, you’ll need to change ObjLibrary.menu.htm. Search for this code:
if ( moi.filesystem.fileExists (iconname) ) { document.write ('<div class="preview"><img class="icon" src="'+ iconname.split("\\").join('/') +'?'+randomID+'"></div>'); }
and replace with this code (note inclusion of 'file:///z:')
if ( moi.filesystem.fileExists (iconname) ) { document.write ('<div class="preview"><img class="icon" src="file:///z:'+ iconname.split("\\").join('/') +'?'+randomID+'"></div>'); }
Now you should be good to go! :-)
I tried installing it, put the commandbar.htm in the root directory of moi3d, and the customui folder in the root directory like it said above. When I start moi, nothing happens, no new menu items at the bottom, nothing different.
When the instructions say to extract it into the moi folder, does it literally mean into the root moi folder?
UPDATE: never mind, like a dumass I was opening the archive and manually trying to install it, when the directory structure in the archive showed me exactly how it was SUPPOSED to work... facepalm.
Hi MAX
The Line:
var Path = moi.command.getOption('ExePath', false) + "\\snapshots\\";
Doesn't exist in the 84 Snapshot.html file.
The closest thing seems to be this line::
vp.render(w, h).save(moi.filesystem.getProcessDir()+"\\snapshots\\"+time+"-["+vp.name+"].png");
Is that right?
If so, does this example look right to you?
vp.render(w, h).save(moi.filesystem.getProcessDir()+"F:\\Dropbox\\Work\\MOI3D\\snapshots\\"+time+"-["+vp.name+"].png");
Can't seem to make it work
Carlo
Message 6507.224 was deleted
Snapshot in CustomUI stopped working last year after reinstalling all Windows 7 programs to a new hard drive.
Previously it had worked. The snapshots directory is located alongside of "ui" and "commands."
To enable writing to Program Files (x86) \ MoI 3.0 \ snapshots, it was necessary to right click
on MoI 3.0, select Properties, Security, Edit, select my user name, and place a checkmark in
the write box, then apply. (Increases Administrator-like privileges)
Similar to using Michael's method here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.171
I was able to create a snapshot2 directory alongside snapshot directory, but was unable to relocate it to AppData directory.
I modified 84Snapshot2.htm to 85Snapshot2.htm file with
vp.render(w, h).save(moi.filesystem.getProcessDir()+"\\snapshot2\\"+time+"-["+vp.name+"].png");
and also modified the end of the last line to ==">Snapshot2</moi:CommandButton>
Also need to rename the function name to "function snapshot2(w, h, button, shiftkey, ctrlkey)
as well as its call in the last line.
Also added the snapshot and snapshot2 subdirectories to the file directory library for quick viewing access.
Is there a way to get CustomUi to work on Windows 10?
https://www.dropbox.com/s/vgs6cu0h454fwkg/test.png?dl=0
Hi ndrakey,
re: Is there a way to get CustomUi to work on Windows 10?
It does work on Windows 10 already, but it needs the final release of MoI v3 in order to run. From your screenshot it looks like your problem does not have anything to do with Windows 10, it's that you're running an older release of MoI which doesn't have the getUIDir() function that the error message is referring to.
Message 6507.228 was deleted
Balloons anyone? How to add mod your GUI with helpful tooltip commands:
sidePaneToolTipCode.zip
After some tricky tests :)
Seems using Custom UI with the cool Kitbash by Chipp Walter (42 item)
http://moi3d.com/forum/index.php?webtag=MOI&msg=8398.1
that Name of Image and file 3dm must be the same and in Uppercase!
Size of image seems have no incidence!
Edit!
After new tests!
Image name and file 3dm must have excatly the same name!
Case is sensitive!
Unfortunatelly I got error message like this when starting Moi after copying files to Moi folder. Win10, any idea how to solve this problem?
I would double check to see that the files are in the proper directories.
Are you using MOI v2 or MOI v3?
Hi Dreviou,
You'll get that error if you're using MoI v2, the CustomUI requires the final release version of v3 so to solve it you'd need to update to the current version.
Message 6507.236 was deleted
That was it, v2, thanks guys! Now it works fine.
Hi
Does this still work? I get an error like the one above (for mac users) but I am on pc?
Hi cnever,
Yes, it still works with the current version. You'll get an error if you're using an older version of MoI though.
160-179
180-199
200-219
220-239
240-259
260-279
280-299
520-522
