90-109
110-129
130-149
150-169
170-189
190-209
210-229
510-522
""""Not for me, unfortunately,""""""""""""""
Ok I got it... It's not permissions. It's the exepath entry in the ini file. Mine was still pointing to the old beta.
Set that path to the new beta folder and see what you get.
On first launch of the new beta I had an error message stating couldn't find customui directory and a file dialogue box asking me where Moi.exe was, pointed to it and everything works as it should.
If you still have your previous beta installed get rid of it then try again.
Wonderful!
Many thanks.
Mike.
Hi BurrMan, hi Mike,
thanks a lot - now the buttons appear ..
Moritz
This Addon is sooo cool!
i always wanted a object library. and it so easy to use and manage!!! :-)
please Keep working on it. it's worth.
Does it possible to have inside the ExtScriptsFull the list of the lines scripts who are inside the Options / ShortCuts keys button?
Now we have the possibility to make a button on the bottom bar with an icon but just a text inside the list ?
Hey Frenchy,
I put all my inline scripts into js files and keep them in a folder named "scripts" in MoI's root.
Then I made a second custom ui command bar icon that looks in that folder...
Cool!
The js file must have a particular syntax or we just put the lines script inside ?
Have you an example text with 2 lines scripts ?
Just paste your inline scripts into notepad then do a save and manaully type the .js extension.
Not sure what you mean by an example?
Ok Frenchy I figured out what you were asking.
You don't put "all your inline scripts" into 1 single file. You make a single js file for each one. Then, the name of that file is available to MoI's command entry area by typing the name, and Max's ui plug will also read them and display them....
So file "100GradientStyles.js" contains this text:
script: /* Make gradient styles */ var red = 12, green = 15, blue = 20; for ( var i = 1; i <= 100; ++i ) { var style = moi.geometryDatabase.addStyle(); style.name = 'Gradient ' + i; style.color = ((red%256)<<16) | ((green%256)<<8) | (blue%256); red += 2; green += 3; blue += 7; }
one file by script :)
It's not so bad!
But I am sure than Smirnov of Michael can make better! :)
Hi guys,
I just rebooted my aging Dell Precision 390 workstation from WinXP Pro to Win7 Enterprise (both 32 bit) since MS dropped XP support this month. I just added the Custom UI to my clean March MoI Beta install. Wow, this is so cool! I love MoI and you just made it better, THANK YOU to all involved!!!
Like some others in this thread I had some issues with things not working such as Snapshot and the "+" feature in the Object Lib. All of that has been resolved by running MoI in Admin Mode.
Only one minor issue is still lingers and that is the view-port nav buttons disappearing for a while and then coming back after a while. The "Reset all" button in the panel always works so this is not major but oddly I can't seem to nail down what will bring it back up. I may have to do a few operations to the model in a given view-port or hit the "Reset all" button and they will appear in one view. But if I leave that view to work in another view it will not come up in the active one.
If any one has a solution that would be very helpful.
David W.
The custom UI has not been working correctly for the Mar-24-2014 MoI beta, on my windows7 computer.
I could not figure out why a newly added script would not be updated in the custom UI. It did occasionally update,
after the new file was also added to the previous MoI beta command folder. So it is not a cache issue.
I finally edited the ini file, accessed from the MoI program, and found that the file directory was set for the prior MoI beta.
After editing the ini file to the correct C:\Program Files\Moi 3.0 beta Mar-24-2014, the custom UI is working correctly again.
I do not know how the problem originated. Maybe from importing a .3dm?
The previous MoI beta is now uninstalled and deleted.
So maybe it is best to uninstall old MoI betas?
Brian, I had to do the same. Took a bit to figure out the issue. You have to love computers...
Ron
Normally I'd recommend keeping an old beta around for at least a couple of weeks after a new beta is out, just in case there are any new bugs in the new beta that get in your way.
For the case of CustomUI in particular you will need to edit its path to go the new beta.
Thank you Michael :-)
All scripts have been rewritten using newest filesystem functions. Mac users now can rename and delete objects in the Object library.
Check the first post for update.
P.S. Added CustomUI version of the Dinos Script Palette script.
http://moi3d.com/forum/lmessages.php?webtag=MOI&msg=5993.1
Cool :)
Does the manual of the first page is changed ?
Hi Pilou
I changed scripts only.
Thx for the info! So no new translation to make! :)
90-109
110-129
130-149
150-169
170-189
190-209
210-229
510-522
