Full Version: CustomUI
Show messages:  1-20  …  41-60  61-80  81-100  101-120  121-140  141-160  161-180  …  521-522
20 Feb 2014   [#101] In reply to [#99]
Fabulous! Now Success is complete! Bravo! Thx both of you! :)
I have used the Michael's method, but will test the Max's method also! ;)
And I see that I have not Translated the LineWeb Command! (if possible) ;)
P I have forgotten to make a transparent image PNG! So background icon is here white!
20 Feb 2014   [#102]
Trying the Max line, works very fine also and some more short to type! ;)
Max method: command="LineWeb"
Michael method : onbuttonclick="moi.command.execCommand( 'LineWeb' );"
20 Feb 2014   [#103] In reply to [#102]
Michael also said about "command=" method. ;)
P.S. Check this thread: http://moi3d.com/forum/messages.php?webtag=MOI&msg=6440.1
20 Feb 2014   [#104]
LineWeb in French! ;)
http://moiscript.weebly.com/lineweb.html
20 Feb 2014   [#105] In reply to [#20]
I haven't been reading (following) this thread for sometime. Back when I did I was wondering about just how to install the script on my Mac.
Are there many new developments I should be aware of? Thanks I look forward to any responses!
21 Feb 2014   [#106] In reply to [#105]
>>raytownmike
>>..how to install the script on my Mac
1. Go to the first post in this thread and download CustomUI.1.0.mac.zip
2. Right-click the MoI app icon and choose "Show package contents". Go into drive_c/moi/ui. Backup CommandBar.htm
3. Extract CustomUI.1.0.mac.zip to drive_c/moi
21 Feb 2014   [#107]
Can you give me the process for a Script to the Commandbar?
Say i have this one
script:/*Loop Selection*/moi.geometryDatabase.selectLoop();
Seems ... onbuttonclick="Loop Selection">Loop Selection</moi:CommandButton>
don't work ?
21 Feb 2014   [#108] In reply to [#107]
Hi Pilou
<moi:CommandButton icon="..." onbuttonclick="moi.geometryDatabase.selectLoop();">Loop Selection</moi:CommandButton>
21 Feb 2014   [#109] In reply to [#108]
Huhu
of course if we must type all the script that is an another story! I could not find that !
Many thanks!
21 Feb 2014   [#110]
Tested! Bravo!
Button of the BarCommand for a script (not a Command) works very fine!
21 Feb 2014   [#111] In reply to [#106]
I get to the final step and not sure what to do because to use the words Extract CustomUI.1.0 what does that mean.
For example: Replace something from existing contents? Sorry
21 Feb 2014   [#112] In reply to [#111]
3. Extract files from CustomUI.1.0.mac.zip to drive_c/moi
21 Feb 2014   [#113] In reply to [#112]
And on the mac to get to the drive_c/moi directory, right-click on the Moi app icon and choose "Show package contents" on the menu that comes up. Then inside of there you will be able to find drive_c/moi.
21 Feb 2014   [#114] In reply to [#113]
I am find where I need to go c/moi its do I replace current contents add to or what? Sorry
21 Feb 2014   [#115] In reply to [#114]
Hi mike,
You need to add the contents of the zip there. There will be one file that will be overwritten, then rest are added files.
So inside the zip are 3 directories: "objects", "snapshots", and "ui".
The "objects" and "snapshots" directories will be new - MoI does not already have any directories there of those names, so just move both of those there under drive_c/moi so that you now have directories drive_c/moi/objects and drive_c/moi/snapshots.
MoI already has a /ui folder, and you want to merge the contents of this new one onto the existing ui folder, not just completely replace the entire ui folder.
There will be one file /ui/CommandBar.htm that should get overwritten by what is in the .zip - the other things in the .zip should just be added to the ui folder.
Hope that helps!
21 Feb 2014   [#116] In reply to [#115]
Thanks Michael. Isn't it amazing how much we take installers for granted!
24 Feb 2014   [#117] In reply to [#116]
I believe I have followed the instructions properly but I don't see the new interface add-on.
24 Feb 2014   [#118] In reply to [#117]
Hi Mike,
It should show up as some new things on the bottom toolbar. Make sure that one particular file "CommandBar.htm" has been replaced by the one in the .zip file. If you see no difference in the bottom toolbar it probably means that file has not been updated.
24 Feb 2014   [#119] In reply to [#118]
I have placed the new CommandBar.htm (Aug 15,2013) 4KB into the Moi/ui folder. Still nothing.
Sorry for all this screwing around.
24 Feb 2014   [#120] In reply to [#119]
Hi Mike,
check please, is Moi/ui/customui folder exists?
